It is a dual voltage charger, and will automatically switch between voltagesa 9V charger instead of the typical 5V charger?
I want a 9v for the car.
I am using the Verizon fast car charger. Works as advertised and is as fast as the stock charger. It comes with an attached microusb cable. It has a light at the end of the microusb cable which is nice at night. Those that get an employee discount can probably get 25% or more offIt's been a month has anyone found a decent 9v changer for the house as well as for thebcar? Thanks in advance
Well I'm usually running Waze the entire time so....
I've found that the fast charging when plugged to the wall is pretty fast until about the last 15-20% of battery. My Note 4 takes forever to charge the last 12%, it probably takes about half an hour. I estimate it takes around an hour and a half to an hour and 45 minutes to completely charge my phone from near dead
The Verizon fast car charger does about 45-48% in 30 minutes, assuming phone isn't in use. This is similar to the stock Samsung adaptive charger.Okay, that makes WAY more sense then! I was gonna say, I can easily go from 40% battery to 85% in about 33 minutes with the stock adaptive wall charger. I was hoping to buy the Incipio car charger and was initially worried about your original post - I bought the Powermod fast charger for my car and it barely charges 21% in 30 minutes.
I just ordered an Anker USB 2A car charger from Amazon today. I'll report back on whether it supports the fast charge.
No, it is the one I linked to earlier in this post.Are you talking about this one that's listed for the S4 and Note 2?
http://www.amazon.com/Verizon-Rapid-Charger-Samsung-Galaxy/dp/B00COT161M/ref=sr_1_3?s=wireless&ie=UTF8&qid=1416868920&sr=1-3&keywords=Verizon+fast+car+charger+note+4
Waiting for it also
My experience is to go ahead and order it now. It should be back in stock within a couple days. They'll notify you by email.
See post 51 above for an "adaptive fast charging" car charger. I just got it and it works great.
Still no "adaptive fast charging" wall charger available yet (that I can find).
When accessories are back-ordered, Samsung won't take an order...they have to email you when they get stock.
