07-30-2016 03:10 PM
81 123 ...
tools
  1. larry0071's Avatar
    I have a Verizon Note 4 pre-order and I keep a charger at home as well as at work. The phone will arrive with the one factory charger, and I searched a bit on Amazon looking for a "Note 4 9V charger" after reading a comment that you need a 9V charger instead of the typical 5V charger to make use of the fast charge feature.
    Has anyone located a fast charge compatible charger on Amazon, and if so, could you throw out a link by chance?
    I appreciate any help
    10-16-2014 03:51 PM
  2. Nakrohtap's Avatar
    Why look on Amazon when you can get the real deal at Samsung for 50% off using code r1H01X01?
    Adaptive Fast Charging Wall Charger (Detachable microUSB-USB Cable), White | Samsung Mobile
    This is by far better than any deal on a knockoff that you will find...and it will work the way it was intended.
    Kegman, Ntchwaidumela and sqa4life like this.
    10-16-2014 05:43 PM
  3. Almeuit's Avatar
    Nice! I looked the other day and didn't see one.. I may get this now .
    10-16-2014 05:46 PM
  4. Almeuit's Avatar
    And it's cheaper than the 2a charger.. Crazy
    10-16-2014 05:48 PM
  5. ejcrossl's Avatar
    Says backordered now
    10-16-2014 05:57 PM
  6. Nakrohtap's Avatar
    That sucks. I would rather wait a few weeks and get a decent charger than being impatient and getting some crap off of Amazon that I would most probably regret later.
    Ntchwaidumela likes this.
    10-16-2014 06:19 PM
  7. larry0071's Avatar
    The link goes to a dead page now, Samsung must have pulled the page down for some reason since you put the link up last night.
    10-17-2014 05:27 AM
  8. ronb's Avatar
    I doubt it is 9v. It is probably 2A 5v. Typical Android chargers are 1A and the pre lightning iPhone chargers are 2.1A.
    There are many chargers that do both on Amazon. One charger can do 1A and 2.1A depending on which port you use.
    Good Luck!
    10-17-2014 07:16 AM
  9. boufa's Avatar
    It is a 9v 1.67 amp charger... Just looked at mine. It is a physics thing.. Can't charge faster than the current is flowing. Sorry about you icrap not having the biggest, fastest best charger.
    Oh and I use 2 amp chargers all the time on my Android devices and it takes advantage of it quite nicely.
    Attached Thumbnails It's there an aftermarket charger that supports fast charging of the Note 4?-2014-10-17-10.44.28.jpg
    10-17-2014 09:45 AM
  10. worwig's Avatar
    Most chargers are fairly stupid. You can typically get a no brand 5 volt charger. They have 5 volt output, and the phone adjusts the power going to the battery. But they are reaching the limits of what you can get at 5 volts. So Samsung appears to have put some smarts in the charger. The Samsung charger can set the output voltage up to around 9 volts. That gives the phone more to work with to get what sounds like around 3 amps into the battery (50% in 30 minutes, about a 1C rate). Then the CHARGER voltage falls back to the normal 5 volts.
    IMHO, if you must have the 9 volt and fast charger rate, only ever use the original Samsung charger. I will be using my many cheap 5 volt chargers for a slower charge myself.
    10-17-2014 10:16 AM
  11. ronb's Avatar
    I was wrong. I just picked mine up and it does go to 9v to fast charge.
    Sorry about the misinformation.
    10-17-2014 10:57 AM
  12. curney's Avatar
    I want a 9v for the car.
    gottria likes this.
    10-18-2014 04:51 PM
  13. newboyx's Avatar
    https://www.qualcomm.com/products/sn...n/quick-charge Qualcomm has a list of certified quick charge accessories.
    Sent from my Nexus 5 using Tapatalk
    iGalione and PaulaO like this.
    10-18-2014 04:55 PM
  14. Old Guy 59's Avatar
    Any ideas on the best car charger for our Note 4s?
    10-18-2014 05:46 PM
  15. iGalione's Avatar
    guess I'll be returning the samsung car charger that I have and the S-view case/back...
    but on another Note (see what I did there?) the protective cover that they sell is actually pretty good and snug, a little more snug than the one that was available for the note 2. Gotta love it!
    10-18-2014 06:54 PM
  16. sodaboy581's Avatar
    Thanks for this, now I can get a fast charger for the car!
    10-18-2014 07:45 PM
  17. mty msi's Avatar
    Car Charger Lightning Cable-4.8 Amp High-Speed | Incipio
    Incipio has 15% off & free shipping so it's less expensive to order directly from them than buy on Amazon.
    10-18-2014 07:45 PM
  18. Old Guy 59's Avatar
    Thank you mty msi!!!
    10-18-2014 07:52 PM
  19. curney's Avatar
    Woah! Is this as fast as the Samsung charger that the phone comes with?
    10-18-2014 07:57 PM
  20. mty msi's Avatar
    According to Qualcomm's website from the link posted above this Incipio car charger is Qi 2.0 certified which is what the fast charge is on the N4. Whether it's as fast as the included Samsung wall charger I don't know. The N4 doesn't come with a 12v car charger. I'm ordering one.
    curney likes this.
    10-18-2014 08:11 PM
  21. curney's Avatar
    From the Engadget review, "I clarified with Samsung that it chose a proprietary solution instead of licensing Qualcomm's QuickCharge tech, but it insisted that you could still use QuickCharge 2.0-compatible chargers to achieve the same results."
    I am ordering now too. Thabks
    10-18-2014 08:22 PM
  22. mty msi's Avatar
    That's good to know that even though the N4 isn't using Qi 2.0 the Qi 2.0 chargers do work.
    10-18-2014 08:55 PM
  23. anon(363857)'s Avatar
    More confirmation that the Note supports both fast charge options:
    Galaxy Note 4- To use fast charging, what kind of charger should be used? | Support | SAMSUNG Saudi Arabia
    [FAQs] Smart Phone : Galaxy Note 4- To use fast charging, what kind of charger should be used?
    Fast charging uses battery charging technology that charges the
    battery faster by increasing the charging power. The Galaxy Note 4
    device supports Samsung’s Adaptive Fast Charging feature and
    Qualcomm Quick Charge 2.0.
    To use Fast charging on your device, connect it to a battery charger
    that supports Adaptive Fast Charging or Quick Charge 2.0.
    EDIT: Where is the 15% off discount? I don't see it on incip's website...
    10-18-2014 09:04 PM
  24. mty msi's Avatar
    Incipio 15% discount code is INC15NOW
    10-18-2014 09:16 PM
  25. stanleybb50's Avatar
    Thanks - worked perfectly. Effectively bumping this thread up so others can see as well.
    This is a great feature to have fast charging in the car as well. Frankly I think more people have a need for quick charging in the car vs home.
    10-19-2014 07:50 PM
81 123 ...
  1. Got an update today.
    By JRechis in forum Samsung Galaxy S4
    Last Post: 10-17-2014, 04:55 PM
  2. Replies: 4
    Last Post: 10-17-2014, 03:17 AM
  3. IT'S HERE!!!
    By browetally in forum Samsung Galaxy Note 4
    Last Post: 10-16-2014, 10:24 PM
  4. Why isn't the time on my all of my apps syncing (Galaxy S4)?
    By Almog Levi in forum Samsung Galaxy S4
    Last Post: 10-16-2014, 03:56 PM
  5. Why isn't my Note 10.1 (2012) not being recognized?
    By sunnysh in forum Samsung Galaxy Note 10.1
    Last Post: 10-16-2014, 03:39 PM
