1. Closingracer's Avatar
    Anybody has one? I am curious about it
    Sent from my SM-N910T using Tapatalk
    10-16-2014 08:40 PM
  2. Greg C's Avatar
    What type of case are you specifically inquiring about?
    10-16-2014 10:10 PM
  3. Closingracer's Avatar
    The one Samsung sells.... They only sell 1 "case" . The flip covers I don't consider a "case"
    10-16-2014 10:11 PM
  4. Greg C's Avatar
    I assume you are talking about the S-View case. I use one for my Note 3 and I have been happy with it. It protects really well without adding too much bulk. I did a Google Search for the Note 4 S-View cases, but couldn't find one.
    10-16-2014 10:20 PM
  5. areyes163's Avatar
    Samsung also sells a hard case. I ordered it. If I find the link i will post it.
    10-16-2014 10:22 PM
  6. Closingracer's Avatar
    No it is an actual Case ... None of that S-view , Flip covers, Wallet ones or etc it is an actual Case
    Galaxy Note ® 4 Protective Cover, BLUE
    10-16-2014 10:24 PM
  7. mpape12's Avatar
    How about you go buy one and tell us how it is? Also, your whole "actual" case classification is great.
    fredwardnelson likes this.
    10-16-2014 10:48 PM
  8. vader4633's Avatar
    Ordered a blue back case and the external battery charger both for 50% off using the coupon code. Both will be delivered on Monday.
    10-16-2014 10:53 PM
  9. Closingracer's Avatar
    A case is something it covers back and sides and bumps up the phone off the glass. Also don't want to waste $15 with 50% off to just throw out
    10-16-2014 10:58 PM
  10. stanleybb50's Avatar
    10-16-2014 11:35 PM
  11. sux2bu's Avatar
    you should contact Samsung and let them know their case is not a case.
    10-17-2014 12:15 AM
  12. dpham00's Avatar
    I got the blue one. Should be here in a few days
    Sent from my Verizon Samsung Galaxy Note 3
    10-17-2014 12:30 AM
  1. Synch contacts between Note 3 & Outlook over USB?
    By JohnZipper in forum Samsung Galaxy Note 3
    Last Post: 11-02-2014, 04:08 PM
  2. is there is a way to create a restricted profile on galaxy note 3 ? SM-900
    By C-Mody Mostapha in forum Samsung Galaxy Note 3 Rooting, ROMs, & Hacks
    Last Post: 10-26-2014, 07:03 PM
  3. For those that have the Note 4, can you try this test?
    By goin_nil in forum Samsung Galaxy Note 4
    Last Post: 10-16-2014, 11:05 PM
  4. 4.4.2 available for AT&T Note 8
    By beh in forum Samsung Galaxy Note 8.0 Tablet
    Last Post: 10-16-2014, 04:24 PM
