03-16-2015 01:02 PM
36 12
tools
  1. 1donos's Avatar
    My note 4 would not stay connected to a call either. I could sit in the exact same spot using my s5 and talk for an hour. I am with verizon. I had the same problem with my note 3. I went through 3 of the note 3's thinking it was a defect. I did not have this problem with my note 2. I ended up returning the note 4 and I am back using the galaxy s5. I hate the small screen and miss my s-pen!! I personally think it is a design flaw...I cant believe samsung quality control would be so bad I ended up with 4 phones that were defective???
    01-09-2015 10:29 AM
  2. Jamie Wooten's Avatar
    I've had mine since November and I haven't experienced any problems. I was in a 45 minute conference call last week with no trouble.
    01-09-2015 11:23 AM
  3. MrToneBoneZ's Avatar
    I'm on ATT and my note edge experience has not been the best either in terms of dropped calls. I bought the phone at launch and my first edge had an unresponsive side screen so I exchanged it within the first 14 days. The second edge worked perfect with no issues at all ....for a while. After a few weeks my phone could not maintain a phone call. On every phone call I made the phone would drop the call and give me the message, No service available or out of network range. I called ATT and they said it was a sim card issue so I replaced the Sim. Her I am over a week later and still suffering from dropped calls although not as frequently. I plan to call ATT and let them know about the continued dropped calls but I do not want them to exchange my device with a refurb!
    02-09-2015 11:08 AM
  4. Carrie Greicar's Avatar
    I have AT&T and a Note 4 and I haven't had any issues with calls dropping.
    02-09-2015 01:16 PM
  5. shaleem's Avatar
    No problem with dropped calls here.
    02-09-2015 05:09 PM
  6. GregMargie's Avatar
    Not one dropped call yet. On Verizon
    Same here.
    02-09-2015 05:19 PM
  7. troshs's Avatar
    My boyfriends note 4 does the same thing. Other phones work perfectly fine in the same location, including my S5. Sometimes my phone will ring and his will never even know it had a call. Texts come in twice sometimes or not at all. It gets very annoying. AT&T says he's on the borderline between 2 towers' coverage but he should still get service if that's the case.
    Boom! From My S5
    02-10-2015 12:00 PM
  8. jayk82's Avatar
    No problems with AT&T in West Texas either.
    Sent by my Note 4 on Tapatalk
    02-10-2015 12:43 PM
  9. lwanderson3's Avatar
    Same issue here. Maddening.
    02-11-2015 04:53 PM
  10. recDNA's Avatar
    My first note 3 never dropped calls. My asurion replacement does intermittently. I was going to get a note 4 but I don't like the sounds of this thread. Gotta stay android so not sure which new phone to buy now.
    03-16-2015 12:11 PM
  11. tsparks1's Avatar
    Lol, I used to work for ATT. get used to the dropped calls.
    03-16-2015 01:02 PM
36 12
  1. having radom webpage connection issues
    By Pen J in forum Samsung Galaxy Note 10.1
    Last Post: 10-17-2014, 05:56 PM
  2. Brand new galaxy note 3 battery draining issue
    By Villainz in forum T-Mobile Samsung Galaxy Note 3
    Last Post: 10-17-2014, 01:54 AM
  3. Why has my HTC ONE MAX stopped the Auto Backup?
    By TruColors100 in forum HTC One Max
    Last Post: 10-17-2014, 01:27 AM
  4. SD card issues
    By SteveISU in forum Samsung Galaxy Note 4
    Last Post: 10-16-2014, 09:30 PM
  5. Why is my Android having WIFI issues after TWRP installation?
    By Matthew Selting in forum LG Optimus Series
    Last Post: 10-16-2014, 05:31 PM
