07-20-2016 05:12 PM
85 1234
tools
  1. ronb's Avatar
    I have an issue with my adaptive fast charging. When turn fast charging is turned on, I noticed that when I plug in my charger there is a little notification that says "adaptive fast charging". But on 2 occasions after using allcast app and my battery level was around 10-20%, it no longer "fast" charges. I've reset, turned off the phone, power saving turned off, and still not luck. After 4 hours charging my battery level is only at 80%. I've reset my phone already to factory, but still took a couple of times unplugging and plugging the charger to get the "fast" charging to work again. It was charging fine until yesterday again. Any thoughts?
    Try another cord and if available another charger brick with your cord.
    If those fail try another battery. I hope you have a friend with another Note 4.
    Good Luck!
    Ron
    11-12-2014 08:28 AM
  2. Kamal Marjit's Avatar
    check on the qualcomm adaptive fast charging on their website
    Qualcomm site says - its backward compatible - so you can use this for other products running on the 800 processor - it won't damage the product - but yes - it won't charge fast either
    11-18-2014 10:16 AM
  3. Tkbredx's Avatar
    I lost my fast charging brick (outlet part) the other day. Smh
    11-18-2014 01:27 PM
  4. rhuzel24's Avatar
    Good Luck!
    Ron
    It also happening to me right now! My phone isn't charging that fast. Help.
    11-20-2014 10:57 PM
  5. rhuzel24's Avatar
    Hey, I experiencing it right now, do you have any more suggestions to fix that?? Coz, I have done that already but still im suffering from slow charging. help. Thanks.
    11-20-2014 11:22 PM
  6. Tkbredx's Avatar
    Found my brick! Lol
    11-23-2014 08:48 PM
  7. ilordvader's Avatar
    Some charger have more than 2.1 amps
    is it safe to charge our phones with it ?
    will that fast charge or damage our phone ?
    2.4
    Robot Check
    4.2
    Robot Check
    11-24-2014 12:56 AM
  8. Danny Huynh's Avatar
    I have the same problem..its annoying as hell cause you see the fast charging bolt for a split 2 secs....then it disappears...
    ive tried unplugging...replugging...plugging it in half way...all the way...changing cords...and plugging into different outlets...
    please....for the love of kimchi....will samsung come up with an answer for us
    11-26-2014 03:12 AM
  9. ronb's Avatar
    The notification only displays when you first plug it in for a couple of seconds. Then on you assume you are fast charging. To make sure and get comparisons, get the Galaxy Charging Current App. The free version will tell you charging mA. Check it after it has been plugged in about a minute. The battery settles in a little.
    Good Luck!
    Ron
    11-27-2014 08:47 AM
  10. Jose Bonet's Avatar
    for those of you saying that you can use the charger and cable from the note 3 on the note 4 ..at least for me is not true...the connection on my Note 4 doesn't allow for the old Note 3 Cable to connect...AM I missing something?
    11-27-2014 12:00 PM
  11. jpr's Avatar
    No one said you can use the cable. You can use the charger. The Note 4 doesn't have a USB 3.0 port so you can't fit a 3.0 cable.
    11-27-2014 12:08 PM
  12. Ishan Sethi1's Avatar
    If I buy the right Hardware needed (The Plug), will it work on the S5? Will it charge faster then regularly?? I just need to know. THNX!
    11-27-2014 01:03 PM
  13. jpr's Avatar
    Only the Japanese S5 has it enabled.
    11-27-2014 02:55 PM
  14. jhill110's Avatar
    The gf upgraded to the s5 last month. Hers has a port for 2.1 and another 2.4 amps. Her s5 does some serious fast charging.
    11-30-2014 12:06 AM
  15. jpr's Avatar
    That has nothing at all to do with adaptive fast charging or quick charge 2.0.
    11-30-2014 12:18 AM
  16. Chino Casino's Avatar
    My cable is not working, can I use another cable with the adaptive fast charge plug?
    12-04-2014 10:07 AM
  17. ronb's Avatar
    Sure!
    Good luck!
    Ron
    12-04-2014 11:20 AM
  18. lornahammond's Avatar
    mine is grayed out to. i had to buy a new cord for my adaptive charger . and ever since then it will not work
    12-07-2014 03:50 PM
  19. ChemMan's Avatar
    I use Qi and the charge pad is rated at 700mA, no fast charge here, that number would need to be 2000mA for fast charge.
    12-07-2014 03:55 PM
  20. LaTuFu's Avatar
    You can't fast charge with wireless.
    12-07-2014 06:41 PM
  21. bspill's Avatar
    According to the Qualcom website, the Galaxy Note Pro devices also have the Rapid Charge technology. I wonder if the Note 4 Fast Charger will Fast Charge my Galaxy Note Pro.12.2. There is nothing in the settings that indicate there is fast charge capabilities.
    12-07-2014 07:05 PM
  22. Rim Tay's Avatar
    I have my note 4 for like 2 weeks and love it . the adaptive fast charging is awesomea. Its just as fast as the droid turbo. As long as I leave the screen off not the whole phone I can get from 20% to 60 in like 25 mins Dead to full in less that 35 But it won't work with out the charger it came with or a replacement one And don't use them on other phones It friend my bro I'm laws phone
    12-11-2014 01:25 AM
  23. altec135's Avatar
    Has anyone have this issue? When charging on adaptive charging and using phone my phone gets really hot at 122 degrees. Then the screen would dim.
    01-11-2015 10:56 PM
  24. dpham00's Avatar
    Something is wrong. I use fast charging with the screen on and it gets no where as hot
    Sent from my Samsung Galaxy Tab Pro 8.4
    01-12-2015 09:32 AM
  25. altec135's Avatar
    Hmmm...I seriously just got this phone last week. I recently switched from Iphone to android and this makes me worried. Maybe I'll go and exchange for another and see if that one does it.
    01-12-2015 10:02 AM
85 1234
  1. Note 4 Google Search freezing/locking up when I go to settings
    By jj482 in forum Samsung Galaxy Note 4
    Last Post: 10-28-2014, 12:18 PM
  2. Note 4 Video on demo models
    By mango1228 in forum Samsung Galaxy Note 4
    Last Post: 10-22-2014, 05:33 AM
  3. Note 4 Hand cent messaging app
    By bbj71370 in forum Samsung Galaxy Note 4
    Last Post: 10-20-2014, 08:06 PM
