Can you still use the phone while it is charging?
Can we do fast charging with Wireless charges too ?
Hello, I was wondering If anyone knew if I could use the fast charge with my other notes? The note 8 and note 2, or would it damage the battery? Thanks
Nope, you can't. The Note 4 has specific hardware that enables fast charging.
I saw posted that the phone will make use of whatever current it has and that a faster 2amp charger still charges faster than the previous or similar phones.
But yes, to maximize the fast charge the screen should be off. But no matter how you cut it, this baby charges quick. No matter the circumstances.
The charger that I brought that's specifically for Samsung doesn't work with the note 4
Posted via the Galaxy Note 4
For the Note 4, do you have to use the fast adaptive charger or can you also use the regular chargers from previous Note models?
The Note 4 has a unique charger, so you need to use the one specific to it. However, that doesn't mean older chargers shouldn't still work at least from my understanding they still should. They'll just be charging at 'normal' speeds.
