07-20-2016 06:12 PM
85 ... 234
tools
  1. jpr's Avatar
    I wonder if anyone could help me please? I recently left my fast charger at a hotel, i collected it today and I don't think it's mine, it doesn't say fast charge when I plug it in anymore and the output says 5v - 2.0A can anyone confirm this for me before I ring to complain please? Thank you.
    The fast charger is 9 volt.
    06-15-2015 01:46 PM
  2. J D Flickinger's Avatar
    Nope, you can't. The Note 4 has specific hardware that enables fast charging.
    07-12-2015 10:20 PM
  3. J D Flickinger's Avatar
    Software not hardware
    07-12-2015 10:20 PM
  4. sj55555's Avatar
    Well, the POS Android 5.0.1 software seems to hosed adaptive fast charging on my phone.
    07-17-2015 12:31 AM
  5. Elvis Ruvalcaba's Avatar
    So let me get this straight. Because my phone doest fast charge anymore. It use to fast charge at any battery level. So im trying to figure out if in fact it only works when the phone is in %10 or less. And at that point, it will charge your phone up to %50 battery and go back to regular charging mode after 30mins of fast charging. theoretically speaking...
    10-04-2015 12:12 AM
  6. hanny kusuma's Avatar
    I have an issue with my adaptive fast charging. When turn fast charging is turned on, I noticed that when I plug in my charger there is a little notification that says "adaptive fast charging". But on 2 occasions after using allcast app and my battery level was around 10-20%, it no longer "fast" charges. I've reset, turned off the phone, power saving turned off, and still not luck. After 4 hours charging my battery level is only at 80%. I've reset my phone already to factory, but still took a couple of times unplugging and plugging the charger to get the "fast" charging to work again. It was charging fine until yesterday again. Any thoughts?
    I have the same problem. Please help... thank you very much
    12-27-2015 01:48 PM
  7. BaconTrousers's Avatar
    Hi everyone. I have a 2 pin Samsung quick charger that I am trying to use with a 3 pin UK travel adapter but it will not charge the phone. I do not have the original white cable that came with the phone and was wondering whether this was the problem? I have many other phone usb cables, but none of them will work with this charger (although they work with non quickcharge chargers)
    12-30-2015 03:13 PM
  8. kirksucks's Avatar
    I've noticed that it won't fast charge with certain cables. Same power brick, but I can't use any old cord.
    01-07-2016 10:10 AM
  9. Michael Seel's Avatar
    There are wireless fast chargers out there, yes.
    06-23-2016 08:05 AM
  10. chadsgotmilk's Avatar
    I know my Note 3 doesn't have the Adaptive Fast Charging option, but if I use this charger will it charge as fast as my old usb 3.0 did or as fast as a conventional Android charger? The Sprint guy told me it would charge the same as my 3.0, but I don't think he realized a phone older than the Note 4 wouldn't have that setting?
    07-20-2016 06:12 PM
85 ... 234
  1. Note 4 Google Search freezing/locking up when I go to settings
    By jj482 in forum Samsung Galaxy Note 4
    Last Post: 10-28-2014, 01:18 PM
  2. Note 4 Video on demo models
    By mango1228 in forum Samsung Galaxy Note 4
    Last Post: 10-22-2014, 06:33 AM
  3. Note 4 Hand cent messaging app
    By bbj71370 in forum Samsung Galaxy Note 4
    Last Post: 10-20-2014, 09:06 PM
