icanfly77
What about the battery charger you can buy? I guess it wont have the hardware to support the fast charging? So in that case its no difference if I just use a Samsung 2amp normal charger with it?
Cheers
Cheers
Yeah I use an extra 2A samsung charger. Takes about 2 hours for a full charge using the battery chargerWhat about the battery charger you can buy? I guess it wont have the hardware to support the fast charging? So in that case its no difference if I just use a Samsung 2amp normal charger with it?
Cheers
Is it grayed all the time or when charging? I believe it is grayed while charging.My "Fast Charging" option is greyed out and checked, but it is not on...?
How come I can't turn it on?
Try another cord and if available another charger brick with your cord.I have an issue with my adaptive fast charging. When turn fast charging is turned on, I noticed that when I plug in my charger there is a little notification that says "adaptive fast charging". But on 2 occasions after using allcast app and my battery level was around 10-20%, it no longer "fast" charges. I've reset, turned off the phone, power saving turned off, and still not luck. After 4 hours charging my battery level is only at 80%. I've reset my phone already to factory, but still took a couple of times unplugging and plugging the charger to get the "fast" charging to work again. It was charging fine until yesterday again. Any thoughts?
If those fail try another battery. I hope you have a friend with another Note 4.
Good Luck!
Ron
Found my brick! LolI lost my fast charging brick (outlet part) the other day. Smh
for those of you saying that you can use the charger and cable from the note 3 on the note 4 ..at least for me is not true...the connection on my Note 4 doesn't allow for the old Note 3 Cable to connect...AM I missing something?
If I buy the right Hardware needed (The Plug), will it work on the S5? Will it charge faster then regularly?? I just need to know. THNX!
The gf upgraded to the s5 last month. Hers has a port for 2.1 and another 2.4 amps. Her s5 does some serious fast charging.
