1. ChemMan's Avatar
    So I turned off my Note 2 and pulled the memory card out and stuck it in the new Note 4. Went to turn back on the Note 2 and nothing. No charge light no nothing, different battery, nothing.
    Any ideas?
    ps the Note 4 is AWESOME!
    10-17-2014 02:11 PM
  2. TechNut79's Avatar
    Can you try to hook it up to your computer and see if you can get stuff off of it. Is that a concern? It probably has to be on which won't help in this case. Won't hurt to try though. Other than that. Try removing the battery for a few minutes and then put it back in and try to power it back on. Also try to charge it. Battery may be dead?
    Note 2 via Android Central App
    10-17-2014 02:25 PM
  3. tarpon6's Avatar
    Put the memory card back in! It was obviously holding the whole thing together!
    10-17-2014 02:28 PM
  4. ChemMan's Avatar
    No love. USB does not even acknowledge it is plugged in or charging. I had just backed it up using KIES.
    Think it will be going back to Samsung.
    10-17-2014 02:36 PM
  5. ChemMan's Avatar
    I am not risking taking that stick out of the Note 4! Are you crazy!
    And what are the chances? Had the Note 4 in hand #1 while the Note 2 dies in hand #2...
    10-17-2014 02:37 PM
  6. TechNut79's Avatar
    That's pretty weird that you get a new device and the old one dies. It knows. IT KNOWS! ๐Ÿ˜Ž
    Jalopiejoe and honey_bee_33 like this.
    10-17-2014 02:47 PM
  7. goin_nil's Avatar
    Till death do us part.
    TechNut79 and honey_bee_33 like this.
    10-17-2014 03:56 PM
  8. delco714's Avatar
    I think that's so spiteful and dramatic... maybe that note 2 's soul is in the new 4
    10-17-2014 04:36 PM
  9. stackberry369's Avatar
    Any ideas?
    You should have unmounted the SD card first
    Posted via the Galaxy Note 4
    10-17-2014 05:19 PM
  10. Slashyou's Avatar
    He turned it off
    10-17-2014 05:22 PM
  11. LewLew23's Avatar
    You took out it's heart, there's no going back
    honey_bee_33 likes this.
    10-17-2014 08:45 PM
  12. Slashyou's Avatar
    He cheated on it
    LewLew23 likes this.
    10-19-2014 08:36 AM
  13. Slashyou's Avatar
    Any ideas?
    Dont cheat on your phone next time
    10-19-2014 08:36 AM
  14. honey_bee_33's Avatar
    That's why when I got the note 4 I had a long breakup talk with my note 3. Hehe!
    girls love tech too
    10-19-2014 09:04 AM
  1. Note 4 Signal Quality so far?
    By Wholesalestunna in forum Samsung Galaxy Note 4
    Last Post: 09-20-2015, 10:08 PM
  2. Replies: 8
    Last Post: 11-03-2014, 11:51 PM
  3. Samsung Extended Insurance for the Note 4
    By Star-Lord in forum Samsung Galaxy Note 4
    Last Post: 10-20-2014, 12:47 PM
  4. safe to use Note 4 charger with Galaxy note 10.1 2014 tablet?
    By monsieurms in forum Samsung Galaxy Note 4
    Last Post: 10-19-2014, 02:47 PM
  5. Why are applications refusing to download on the new Note 4?
    By Aref Afshar in forum Samsung Galaxy Note 4
    Last Post: 10-17-2014, 10:31 PM
