1. tbocfo's Avatar
    The extra tips that come with the S Pen are 3 white and 2 gray. Is there a difference other than color?
    10-17-2014 02:06 PM
  2. itsnotmeitsyou's Avatar
    The white are plastic tips for use on plastic screen protectors. The black/gray are softer tips for glass.
    Sent from my Samsung GALAXY Note® 4
    razortaz18, z71kris and lv2bsilly like this.
    10-17-2014 02:42 PM
  3. Kenneth Brooks3's Avatar
    slightly incorrect, the 'regular' tips, for glass are the color of your Note 4, the screen protector tips are GREY.
    12-26-2014 08:49 PM
  4. adock22096's Avatar
    Do the tips wear out?
    12-26-2014 11:31 PM
  5. cybertec69's Avatar
    That is so true, I have installed the iloome 8H tempered glass, and when I used the S-Pen with the black tips it felt tacky, not smooth at all, then I was at XDA Developers forum and this issue came up, and someone recommended I use the white/grey tip that came with the replacement tips "only 2 white/grey tips in packaging", night and day difference, now the S-Pen is smooth as butter.
    02-01-2015 12:09 PM
  6. ChemMan's Avatar
    The tips are different in composition. The black ones are softer and tend to grip the screen a bit. The white ones are harder and slide across the screen effortlessly. Putting the type of screen protector aside, you should see if you like the grippy black ones or slippery white ones. There really is no correct tip for the S-pen, the only right one is the one you like better.
    02-01-2015 03:09 PM
  1. Note 4 Google Search freezing/locking up when I go to settings
    By jj482 in forum Samsung Galaxy Note 4
    Last Post: 10-28-2014, 12:18 PM
  2. Note 4 Video on demo models
    By mango1228 in forum Samsung Galaxy Note 4
    Last Post: 10-22-2014, 05:33 AM
  3. Note 4 Hand cent messaging app
    By bbj71370 in forum Samsung Galaxy Note 4
    Last Post: 10-20-2014, 08:06 PM
