01-19-2016 01:15 PM
210 ... 34567 ...
tools
  1. thegame161's Avatar
    One thing I've noticed when at the gym you need to make sure your finger is not all sweaty otherwise it won't work
    10-24-2014 05:00 AM
  2. Statastic's Avatar
    I actually love the finger swiping feature. Works alot better than I thought.
    10-24-2014 05:38 AM
  3. Dukins's Avatar
    I plan to keep the feature on. It's worked for me everytime. I have registered four fingers. Its best to use as many angles as you possibly can per finger.
    10-24-2014 08:01 AM
  4. iamdld's Avatar
    It set up easy enough but man I couldn't access my phone! So I turned it off
    This
    10-24-2014 08:28 AM
  5. lostsoul2's Avatar
    How did you set it to unlock with a swipe for 10 minutes then go to fingerprint? I would LOVE to have mine work that way but can't figure out a way to do it?
    go to: Settings>Device tab>Lock Screen> Secured lock time > then set it to what you want.
    10-24-2014 03:45 PM
  6. 15vailo50's Avatar
    Just got my note 4 yesterday... But with going on 20hrs of use I have to say its a go...works 90% of the time...good enough for me!
    Note 4
    UniQue WerkX likes this.
    10-25-2014 04:38 PM
  7. mbabee's Avatar
    Idk if it's just my bad luck or the fact that my phone seems to have more issues than its worth, but the fingerprint scanner barely works for me. I'm keeping it on right now because I kind of like it, despite it being annoying as heck. I registered two thumbs and my right index, even swiped at different angles hoping to bypass having any issues if I was holding the phone differently at the time of unlocking, and it's a pain. I got locked out of my phone and while it was locked I didn't have the option to input my regular password. Wonder why that's even available if you can't use it. Bummed out man.
    10-25-2014 06:17 PM
  8. monsieurms's Avatar
    Note 4
    The only time I find it doesn't work is when--because of old habits and stupidity--I swipe the screen and sort of miss the button. That's hardly, of course, the scanner's fault. Otherwise, it's been quick, easy and reliable.
    10-31-2014 10:18 AM
  9. marvinthmartian's Avatar
    Big thumbs up(no pun intended!) to the fingerprint scanner. I got my N4 3 days ago, and set up the fingerprint scan for security(out of curiosity). Since then, it's worked 9 times out of 10. I'm quite impressed, to be honest!
    11-03-2014 12:28 PM
  10. yo0123yoyo's Avatar
    It's awesome just make sure to register your finger one time swiping normally and one time swiping horizontally, that's what I did and works great!
    Danger_Mouse#AC likes this.
    11-03-2014 01:16 PM
  11. yeatzee's Avatar
    I just tried out the advice on here and registered two different registries for my thumb, one vertical the other horizontal as noted above and its worked flawlessly thus far. Thanks!
    yo0123yoyo likes this.
    11-03-2014 01:58 PM
  12. Duncan1982's Avatar
    I quite like this feature, not the best implementation but it has worked well thus far.
    11-05-2014 05:48 AM
  13. Cavboygt's Avatar
    I like it, the problem is getting cold in cali so I'm wearing gloves. I have to take it off to use the finger scanner.
    11-05-2014 09:51 AM
  14. Almeuit's Avatar
    Yep that is going to be a problem for everyone using any type of fingerprint scanner .
    11-05-2014 01:02 PM
  15. UniQue WerkX's Avatar
    Maybe big fingers are best..works flawlessly for me...also use your index finger for best response....the thumb is the worst response
    I have the opposite issue, either index fingers didn't work like 90% of the time but thumbs work best for me. It is a little quirky but I use it as I'd rather swipe a thumb then enter in a password.
    Posted via Note4 & Android Central App
    11-05-2014 01:27 PM
  16. Almeuit's Avatar
    Likewise. If I used a password I would use a pattern lock.
    11-05-2014 01:35 PM
  17. fragologist's Avatar
    I've had the phone for all most 2 weeks and I haven't tried it yet.
    11-05-2014 02:40 PM
  18. TheDarkKnight0818's Avatar
    when I tried it I had about a 65%-70% success rate, which is good but I dont lock my phone and decided it is easier to unlock my phone just by swiping up.
    11-05-2014 02:49 PM
  19. Danger_Mouse#AC's Avatar
    Did you try registering the same finger multiply times and doing it at different angles each time? If not maybe you should exchange your phone for another.
    mbabee and UniQue WerkX like this.
    11-05-2014 04:11 PM
  20. scheumanrj's Avatar
    Same here. It is so frustrating that I can't get this to work.
    mbabee likes this.
    11-06-2014 10:08 AM
  21. Nitro211K's Avatar
    my success rate went from 60% to 95% by removing the case on my phone and re-registering the fingers, and then putting the case back on.
    64fairlane likes this.
    11-06-2014 10:17 AM
  22. rlanza1054's Avatar
    Tried it! FAIL!
    Sent from my Nexus 7 using Tapatalk
    11-06-2014 10:21 AM
  23. mbabee's Avatar
    Since the phone came with three, I set up a bunch of different options. At the end and what I used for maybe half a day, was two for same thumb, and one for index. I swiped at every angle. Straight down, sort of sideways, etc. I even held the phone in the position I'd be one handedly be unlocking it in, thinking to bypass any issues and still no dice
    11-11-2014 06:58 PM
  24. Andy847's Avatar
    Once I got it set up, it was okay. Pretty accurate, but most of the time I had to swipe more than once to get it right. It was definitely my fault, user error, by not swiping the whole button or not at the angle I used to register the finger. It became more of a problem when I had to swipe multiple times. So just went back to swiping the lock Screen. It's a cool feature, just not worth the effort for me.
    11-11-2014 07:04 PM
  25. AKFL3TCH3R's Avatar
    I've been debating whether to use it or not..? Sometimes it is really difficult to use.
    11-11-2014 07:30 PM
210 ... 34567 ...
  1. Buy the LG G2? Or no?
    By Brian_Geyer in forum AT&T LG G2
    Last Post: 04-09-2015, 07:27 PM
  2. Samsung S5: Facebook Contact Images Not Showing In Messages
    By warrior2486 in forum Samsung Galaxy S5
    Last Post: 11-26-2014, 06:52 AM
  3. Nexus 7 2013 or Nexus 9 ??
    By Justin Emerich in forum General Help and How To
    Last Post: 10-18-2014, 05:10 PM
  4. Replies: 0
    Last Post: 10-18-2014, 05:03 PM
