01-19-2016 01:15 PM
210 ... 6789
tools
  1. RON OLSZOWKA's Avatar
    Here is how to fix this.
    Settings
    Device
    Lock Screen
    Secured Lock Time
    Instantly with the power key or when the screen times out
    01-10-2015 03:41 PM
  2. RON OLSZOWKA's Avatar
    The problem with my solution is that the screen won't time out and lock on its own. With my way you have to manually lock it each time. My way will at least allow you to lock your phone manually and then you will be able to use the fingerprint scanner to unlock the Note 4 every time.
    01-10-2015 03:45 PM
  3. Inquisitive1's Avatar
    Mine works perfectly every time. I've been advised clammy hands and freshly lotioned hands don't work, and that however your prints are at setup is how they must always be.
    Good thing I keep clean hands.
    Posted with my awesome NOTE 4
    01-10-2015 07:00 PM
  4. RON OLSZOWKA's Avatar
    Let me clear something up for those of you who might not have caught this. What I am talking about and what some of you are talking about are two totally different things. I am not talking about the fingerprint scanner not being able to recognize your fingerprint. The problem that me and omarm were having is this. You would have the fingerprint lock all set up. You would lock the screen or let the phone timeout and lock itself. You would then wake up the phone and want to unlock it with your fingerprint but instead of the phone prompting you to scan your fingerprint the phone asks you to just swipe the screen to the left or right. I can't remember. This isn't supposed to happen when you have the fingerprint scanner set up to unlock the lock screen. So you end up having no security because anybody can swipe the screen and have access to your phone. I figured out how to sort of fix this and I already posted the solution.
    01-10-2015 09:05 PM
  5. edtaussig's Avatar
    I liked using it, worked well enough for me, but I disabled it because I found
    that the lockscreen was using a lot of battery - not sure if it's any lockscreen
    or just the fingerprint scanner, but com.android.keyguard was using a decent
    percentage of the battery, and it's apparently a known issue. Can't see why
    that should be since it's only needed when the screen is on?
    01-10-2015 09:19 PM
  6. harryhoudini66's Avatar
    Maybe I missed a post so just in case. There are two different types of timeouts. There is a "Screen Timeout" on the "Display" options that can be set and then there is a "Secure Time Lock" that can also be set under Lock Screen. Although they are separate things, you can get them to work together. Simply setting the fingerprint does not mean that when your Display "goes to sleep" that you will be prompted to use your fingerprint to access the device.
    When I first setup my Note 4, I set my fingerprint and was expecting to immediately be prompted for it when unlocking my screen or after clicking on the Power button. This was not the case and I was just asked to swipe to unlock. It was not until later that I realized that the Secure Time Lock was set to 15 minutes and my Screen Timeout was set to 1 minute. Once I set the Secure Time Lock to "Instantly or when the screen times out" under Lock Screen, this was resolved.
    So, if for example I want my screen to lock after five (5) minutes, I would set the "Secure Lock Time" to "instantly with the power key or with screen timeout" under the Lock Screen options. I would then go to Display and set the "Screen Timeout" to five (5) minutes.
    Attached Thumbnails Note 4 Fingerprint scanner or not?-screenshot_2015-01-11-00-32-52.jpg   Note 4 Fingerprint scanner or not?-screenshot_2015-01-11-00-33-19.jpg
    huntnyc likes this.
    01-11-2015 03:30 AM
  7. RTMobile's Avatar
    Mine works great and I love it and still use it for "Lastpass", I don't use for home screen unlocking because then my wife can't unlock the phone.
    01-11-2015 10:49 AM
  8. harryhoudini66's Avatar
    She can. You can add her fingerprint on as well. She can also use the password instead of the fingerprint when prompted.
    01-11-2015 04:43 PM
  9. efu671's Avatar
    Set up is a breeze but getting it to unlock is very inconsistent - especially if you have dry skin on your fingers. Big annoyance is that if you fail, you have to wait to try and login again. Sometimes it works just right, other times I fail and have to wait. So I turned it off because I hate waiting to unlock my phone.
    02-10-2015 10:21 PM
  10. anon(27512)'s Avatar
    I use it and it works surprisingly well.
    02-11-2015 10:14 AM
  11. Huggie87's Avatar
    I use it as well and rarely have any problems with it
    02-26-2015 05:44 PM
  12. NexusGirlX's Avatar
    I tried it for a few hours and ended up wanting to throw the phone through the wall.
    02-26-2015 05:57 PM
  13. ChemMan's Avatar
    I use it all the time, flawlessly if I pay attention.
    02-26-2015 06:03 PM
  14. natehoy's Avatar
    I have to use a lock screen because I have work email on the device. I find the swipe always works -- always -- if I swipe at the same, slo-o-o-ow speed. Even if I had to do a second swipe, it's still better than punching in a password or pin. That said, I'd still prefer just being able to place my finger on the home button.
    I have work email on my device, but unfortunately we use TouchDown and everything BUT "Password" is "Disabled by administrator, encryption policy, or credential storage". I'd actually set the timeout on my phone significantly lower if they'd let me use a 6-number PIN or fingerprint swipe, but no dice.
    02-26-2015 06:53 PM
  15. kirksucks's Avatar
    Set it up because I was curious. It worked pretty flawlessly but I never lock my phone. I constantly take it out and look at stuff. Swiping my finger every time would suck.
    02-27-2015 01:25 AM
  16. rong21's Avatar
    wasn't impressed with it. Lost patience with it
    02-27-2015 06:59 AM
  17. KBlack2595's Avatar
    I use it all the time and it does have problems at times like when holding the phone and trying to unlock but even if I have 2 do it 2 or 3 times its faster than entering a password I think if it got a update where u could add more fingers or make it so u swipe more when setting it up then it would work a lot belter
    02-27-2015 08:53 AM
  18. road_kill's Avatar
    When I got my note E I went in and set it up first, I ran into the same problem where it would set the finger print but I would still get the swip screen to unlock untill I went into the screen lock settings and set it to instantly with power button or when screen times out. Now everything works fine. Sometimes it can be annoying but im still getting the hang of it.
    02-27-2015 09:28 AM
  19. Skeediddley's Avatar
    Use it all the time. Have set up both thumbs (including one handed hold and swipe angles) and with a bit of practice its getting better and better.
    02-27-2015 01:01 PM
  20. stephfsch2013's Avatar
    I don't use it because when I swipe it the case interferes with the swiping. Big pain.
    02-27-2015 11:11 PM
  21. AxiosENT's Avatar
    I love it just takes time to get used to it
    Sent from my SM-N910P using Tapatalk
    Alberto Suarez likes this.
    02-28-2015 12:12 AM
  22. mty msi's Avatar
    I didn't take the time to read all 8 pages of this thread so I apologize if someone else already posted a similar thread. What I experienced was all of a sudden my scanner wouldn't recognize my fingerprint after about 2 1/2 months of working fairly well so I retrained it and it's backed to working fairly well. Reason I say fairly well is it usually takes 2-3 swipes to work and has always been that way. Sometimes it does work on the first swipe but most times not. Other thing I'll mention is I entered a different swipe for use in my car dock because the angle the phone is being swiped from is different than when you're holding the phone in your hand.
    One thing is for certain, Apple's fingerprint reading mechanism is far superior to Samsung's.
    03-01-2015 12:25 PM
  23. rexb's Avatar
    I have the Note Edge (2 weeks) and it's a hit or miss for me. There are days it works great and days that it's not. And usually if your fingers are sweaty, good luck! I've also tried a friends iphone 6+ fingerprint scanner, it is way alot easier. Just press on the home button and you're done. She did say sometimes it doesn't work when fingers are sweaty as well.
    I'm still using the fingerprint scanner. I just take a deep breath, pray then swipe to open my phone..ha ha..I do have the back-up password if in case it takes a few swipes.
    04-08-2015 12:35 PM
  24. Alberto Suarez's Avatar
    Yes you are right I set mine up and it works great I sometimes have difficulty when I apparently did not swipe my finger on the sensor properly otherwise I am very satisfied.
    07-19-2015 08:39 AM
  25. Neo_ii_Droid's Avatar
    First off, Hello Alberto Suarez and welcome to Android Central!
    I tried it to see how it works, then simply disabled it all together. Not for me and my uses. Of course Your Methods May Vary accordingly so.
    07-19-2015 02:36 PM
210 ... 6789
  1. Buy the LG G2? Or no?
    By Brian_Geyer in forum AT&T LG G2
    Last Post: 04-09-2015, 07:27 PM
  2. Samsung S5: Facebook Contact Images Not Showing In Messages
    By warrior2486 in forum Samsung Galaxy S5
    Last Post: 11-26-2014, 06:52 AM
  3. Nexus 7 2013 or Nexus 9 ??
    By Justin Emerich in forum General Help and How To
    Last Post: 10-18-2014, 05:10 PM
  4. Replies: 0
    Last Post: 10-18-2014, 05:03 PM
