01-19-2016 01:15 PM
210 ... 789
tools
  1. jordyd's Avatar
    When I first got the phone, I thought I could only hold my finger straight and swipe down, but on realised this weekend that I could swipe it with my finger at an angle (as I hold the phone single handed) so I've turned it on now and its great. That was the only thing I didn't like about the Note 4, but even that's sorted now.
    Sent from my Galaxy Note 4
    07-19-2015 03:51 PM
  2. droidntn's Avatar
    I set mine up like I would normally swipe it... Kind of one handed like I'm walking and have it in my right hand. Every now and then I have to reswipe.
    I love it.
    07-21-2015 10:22 AM
  3. Gunny94's Avatar
    Had no issue what so ever with it. I usually never fail the first swipe.. Was used to iPhone 6 swipe but quickly got used to Note 4 when I switched.
    Got both mine and my girlfriend's fingerprint and so far so good, no issue.
    Only problem probably is if you get your finger a little bit wet you can't use it. (it's annoying when you running and you sweat...)
    07-21-2015 12:32 PM
  4. RockAndRollAcdc's Avatar
    does your backup password work?? mine wouldn't work. reset a few times
    07-21-2015 03:10 PM
  5. tadpoles's Avatar
    I never use it. If it had worked like the S6's I may have but it seems like the pattern is just quicker and more reliable for me.
    Sent from Elegance
    07-21-2015 03:20 PM
  6. 1980s's Avatar
    No I don't use it, for me it's just a terrible swiper that only seems to work once every 5 times. It if had the N5 fingerprint scanner it'd be perfect. I'm using the pattern unlock atm.
    11-19-2015 10:26 PM
  7. PublicImageLtd's Avatar
    Works brilliant with my thumb. Changed it from index finger, works well. Most tries is about 3, but mostly first attempt. Love it.
    dabombcra likes this.
    11-22-2015 08:53 AM
  8. JimGarn's Avatar
    My fingerprint scanner does not work. I have tried three different fingers and rarely will it open the phone. Maybe I have weird fingerprints....
    11-24-2015 01:11 PM
  9. PublicImageLtd's Avatar
    Are you spiderman :-)
    11-24-2015 02:09 PM
  10. petersull's Avatar
    My finger print scanner works about once in every 30 swipes and keeps going into the 30 second lock out. Just can't work out what I'm doing wrong. It is just a waste of time.
    01-19-2016 01:15 PM
210 ... 789
  1. Buy the LG G2? Or no?
    By Brian_Geyer in forum AT&T LG G2
    Last Post: 04-09-2015, 07:27 PM
  2. Samsung S5: Facebook Contact Images Not Showing In Messages
    By warrior2486 in forum Samsung Galaxy S5
    Last Post: 11-26-2014, 06:52 AM
  3. Nexus 7 2013 or Nexus 9 ??
    By Justin Emerich in forum General Help and How To
    Last Post: 10-18-2014, 05:10 PM
  4. Replies: 0
    Last Post: 10-18-2014, 05:03 PM
