How many are keeping theirs on? I have mine on right now as it's new but not sure if I will keep it for good or not.
It is just as easy as swiping the screen. No accidental turn on from the screen swipe. I scanned two thumbs and right index finger and can use any of them at any angle, just swipe down. I have it set so it doesn't actually require a finger until it is idle for 10 minutes, screen swipe wakes it during the 10 minutes. I see absolutely no reason not to unless you are simply to lazy to swipe your fingers 10 times to set it up. Swipe at every imaginable angle you might use during the training and it works fricking great.
Hello, I'm having trouble with my fingerprint scanner. After I register my fingerprint it only works once I turn the phone off and back on. After the initial fingerprint scan if I lock it and go back to the home screen the phone no longer asks for the fingerprint but asks me to swipe to unlock. Does anyone know how to fix this problem? Or do I have a defective device
Try following the below screenshots. Ensure you have your lock screen set to fingerprint.
Thanks for your reply. I originally followed all of the steps but no luck. Another used just created a thread with the same problem as mines. Hopefully we can get this resolved... thanks again for the screen shots.
