1. George Gates's Avatar
    Have a problem.
    Jaybird Bluebuds X (bluetooth earbuds) when paired with Note 4 the sound is very low even when turned up all the way.Tried a wired pair of Bose and they worked perfectly with the Note. The Bluebuds work with my ipod with no problem.
    Any ideas ?
    Thank you. George
    10-17-2014 06:58 PM
  2. Almeuit's Avatar
    Weird... I'm trying to think what could cause this. I use my LG ones and they are fine.
    Do the Jaybird ones have their own volume? I turn my phone all the way up and adjust the volume from the LG headsets own volume.
    10-17-2014 07:32 PM
  3. RecoveringAppleUser's Avatar
    I have a note 3 and been having the similar volume issues. You have to increase the volume on the phone and on the headphones. They are separate. Also I've been running into an issue with my jaybirds where it's connected but it'd still playing on your phone. Super annoying.
    11-15-2014 08:39 PM
  4. flexfield's Avatar
    I use the PowerBeats2 Wireless buds and they sound great with volume turned up on both the Note 4 and the PB.
    11-15-2014 08:48 PM
  5. JRLasVegas's Avatar
    Are you using a 3rd party equalizer? It might have conflicts
    Sent from my SM-N910T using Tapatalk
    11-15-2014 08:57 PM
  6. onekajun's Avatar
    I have a galaxy S3 and a Note 4. When paired to my stereo in my Kenworth truck, the Note 4's volume is considerably lower than the S3. I made sure the media volume under the gear tab was turned all the way up. It is such a problem and I don't know what to do at this point. I have finally given up and use my old S3 as a media device now. And use the Note 4 for everything else.
    12-04-2014 10:11 AM
  7. Inquisitive1's Avatar
    Jarv headphones work great
    12-07-2014 10:40 AM
  8. LaTuFu's Avatar
    That is likely an issue with firmware compatibility with your kenworth's head unit. You might want to check with the manufacturer of the head unit and see if they have a firmware update.
    The BT codec that the Note 4 uses is different than the one used by the S3.
    12-07-2014 11:17 AM
  1. Note 4 Google Search freezing/locking up when I go to settings
    By jj482 in forum Samsung Galaxy Note 4
    Last Post: 10-28-2014, 01:18 PM
  2. Note 4 Hand cent messaging app
    By bbj71370 in forum Samsung Galaxy Note 4
    Last Post: 10-20-2014, 09:06 PM
  3. Why is my home screen dim with a full battery?
    By Shalonda Jackson in forum Displays
    Last Post: 10-19-2014, 06:56 PM
  4. Replies: 1
    Last Post: 10-18-2014, 03:19 PM
