04-18-2016 11:34 AM
118 1234 ...
tools
  1. hopefulfarm's Avatar
    I disabled it. It was so annoying
    Rocking the Note 4
    10-18-2014 12:04 PM
  2. Tkbredx's Avatar
    I disabled touch wiz altogether 😂
    10-18-2014 05:07 PM
  3. mveltkamp's Avatar
    Disabled, Pretty useless.
    10-18-2014 05:55 PM
  4. soldier45's Avatar
    It seems ok but buggy and slow to me so disabled it.
    10-18-2014 06:45 PM
  5. Keltian's Avatar
    I disabled it so now I can continuously scroll through my home screens.
    10-18-2014 07:35 PM
  6. doctordwaynewilliams's Avatar
    I have also disabled Flip board even though I use the app often. By the way, the phone simply rocks.
    Written from the mighty pen of my Samsung Galaxy Note 4!
    10-18-2014 07:52 PM
  7. LegalAmerican's Avatar
    Disabled asap. Replaced it with Google Now using the launcher. I got used to it on my Nexus 5 and had to have it back.
    10-18-2014 08:03 PM
  8. zmann's Avatar
    I disabled
    GALAXY NOTE 4, GO BIG OR GO HOME
    10-18-2014 10:34 PM
  9. IrishFXDB's Avatar
    I'm also in the "I installed Google Now Launcher" camp. Google keyboard as well.
    LegalAmerican likes this.
    10-18-2014 10:58 PM
  10. PaulaO's Avatar
    I panicked when I first booted it up, swiped along the screens, got to the last one and it didn't move further. "WTF? I got a disguised iPhone??"
    Quickly figured out it was that stoopid Flipboard and turned it off.
    10-18-2014 11:06 PM
  11. double923's Avatar
    I disabled mine.
    Sent from my SAMSUNG-SM-N910A using Tapatalk
    10-18-2014 11:10 PM
  12. butterfly210's Avatar
    I did... I m just using a widget for flipboard!
    Posted via my Note 4 via Android Central App😃
    Attached Thumbnails Note 4 How many have disabled flipboard from home screen?-screenshot_2014-10-19-00-00-55.jpg
    10-19-2014 12:01 AM
  13. jlczl's Avatar
    Like most others I like Flipboard but I don't want it taking a whole screen. Installed Nova Launcher and got rid of it.
    10-19-2014 12:29 AM
  14. doctordwaynewilliams's Avatar
    By the way, I disable s voice too. No need for that. Google Now is more than sufficient.
    monsieurms likes this.
    10-19-2014 10:38 AM
  15. RexdaleNap's Avatar
    Always have always will.
    10-19-2014 06:49 PM
  16. mrstruegemini's Avatar
    I disabled it also I like my calendar to the left and to able to keep scrolling...and plus I don't care for flip board tried using it on my Note 2 but just didn't like it.
    10-19-2014 09:16 PM
  17. KingTongue's Avatar
    I did hopefully they make it less buggy.
    Posted via My Note 4
    10-19-2014 09:19 PM
  18. fragologist's Avatar
    The first thing I plan on doing is disabling Flipboard and then dialing the bloat.
    I am in the process of making my Note 4 self aware.
    10-19-2014 10:04 PM
  19. Old Guy 59's Avatar
    In another thread a poster mentioned that if you disable S Voice ......Google Now would not work correctly. I "assume" you're not having any problems with Google Now?
    10-19-2014 10:11 PM
  20. rhophotos's Avatar
    I disabled it. It loads slow and stops circular home screen navigation. I just keep the flip board widget from the app on one of my screens anyway.
    10-19-2014 10:14 PM
  21. IrishFXDB's Avatar
    I disabled S Voice on this and on my previous S5, no problems that I've noticed. What sort of issues were mentioned?
    10-19-2014 10:23 PM
  22. shaneontherocks's Avatar
    anyone have daily random flipboard notifications? These pop up as text messages and it's driving me insane and I am sure its wasting my battery! I even went into the app and I dont see any place to turn them off! help pls!
    11-21-2014 05:50 PM
  23. ejohnnyk's Avatar
    I love Flipboard, but disabled this feature as I found it to be annoying.
    hdhuntr likes this.
    11-21-2014 06:54 PM
  24. Trigati's Avatar
    I completely turned FlipBoard off. I tried it a while back, decided it wasn't anything I needed, and never used it since. I don't need the app/process running in the background for no reason. I also use Nova, so the left swipe thing was lost on my device anyway.
    11-21-2014 07:24 PM
  25. M3Stang's Avatar
    I did it. Found it by accident.
    11-21-2014 07:25 PM
118 1234 ...
  1. Sprint Note 4 Simultaneous voice & data
    By sfrsteel in forum Samsung Galaxy Note 4
    Last Post: 04-19-2015, 10:36 PM
  2. Where can I find cheep lcd screens for a Samsung Centura?
    By eviltiger in forum Ask a Question
    Last Post: 10-20-2014, 01:15 PM
  3. Note 4 Display saturation in sunlight.
    By bassplayrguy in forum Samsung Galaxy Note 4
    Last Post: 10-19-2014, 07:16 PM
  4. Note 4 keyboard case
    By cjc085 in forum Samsung Galaxy Note 4
    Last Post: 10-19-2014, 05:36 PM
