06-10-2015 03:21 AM
59 123
tools
  1. Neo_ii_Droid's Avatar
    Quick question here and I don't know if it's already been addressed (I may have missed it). It is fine to charge while in UPSM?
    micktwo likes this.
    04-12-2015 02:55 PM
  2. Neo_ii_Droid's Avatar
    Well I tried it today at work. For some reason it was slow. Then again I was charging via the computer terminal at work and not directly from an electrical outlet. In the former, is that "normal" charge?
    04-14-2015 11:49 PM
  3. bigsmoke79's Avatar
    Perfectly fine to charge in UPSM, in fact I think it charges slightly quicker in this mode but maybe that's just me, would same to make sense as the most of the main power hungry things would be shut down while charging.
    I use UPSM every night when I go to bed, as it saves battery usually only lose 1 or 2 % battery overnight.
    04-15-2015 01:06 AM
  4. Ahren Widman's Avatar
    actually you can use select apps like chrome twitter and faceboom
    04-23-2015 06:13 PM
  5. Byron 5's Avatar
    Nope haven't used it yet, battery life is awesome as it is.
    micktwo likes this.
    04-24-2015 10:20 AM
  6. Ntchwaidumela's Avatar
    I haven't tried it yet. One day I will when I am in a power crunch .
    Me too. I'll try it tonight and leave it on while charging overnight. I'll post what I think.
    04-24-2015 08:40 PM
  7. Neo_ii_Droid's Avatar
    Here's another question I have when utilizing UPSM. Does turning it on and off tax the battery all the more?
    04-26-2015 06:41 PM
  8. Will Beasley's Avatar
    That's your problem. It uses less power than any other power save mode but being connected to the internet and using facebook will still have an effect on your power draw. Limiting to only calls and messaging is really the best use in a pinch. If I turn it on it takes a few hours to drop 1%. Sure you give up Facebook but it is well worth it knowing you can make it an entire day on 8%.
    06-08-2015 10:24 AM
  9. micktwo's Avatar
    check out my youtube vid on the Samsung galaxy note 4 power saving
    Neo_ii_Droid likes this.
    06-10-2015 03:21 AM
59 123
  1. Sprint Note 4 Simultaneous voice & data
    By sfrsteel in forum Samsung Galaxy Note 4
    Last Post: 04-19-2015, 09:36 PM
  2. Note 4 Display saturation in sunlight.
    By bassplayrguy in forum Samsung Galaxy Note 4
    Last Post: 10-19-2014, 06:16 PM
  3. iPhone Notes saved to Google what app to use on Note 4
    By dj2big in forum Samsung Galaxy Note 4
    Last Post: 10-19-2014, 04:53 PM
  4. Note 4 keyboard case
    By cjc085 in forum Samsung Galaxy Note 4
    Last Post: 10-19-2014, 04:36 PM
