1. stackberry369's Avatar
    Where can i find the adaptive fast charging charger so that i can have one for work? And why can't the Samsung specific charger work?
    Posted via the Galaxy Note 4
    10-18-2014 01:49 PM
  2. jpr's Avatar
    Samsung is temporarily out of it. Here is where the page was. I don't know whether they will put it up at the same url when it is back in stock but either way you can see the part number in the URL to search for it easily: Adaptive Fast Charger - SAMSUNG
    Your second question doesn't make sense to me. The Samsung charger that came with your Note 4 should be the adaptive fast charger.
    10-18-2014 02:10 PM
  3. Almeuit's Avatar
    Any charger will work to charge the Note 4... It doesn't matter as long as it's a USB 2.0 slot and the brick can power the cord...
    But..
    If you want the adaptive fast charging then you would need the specific brick that came with the phone. That is the only time the phone will utilize that feature for charging.
    10-18-2014 02:52 PM
  4. stackberry369's Avatar
    But..
    The rockfish charger that's specifically for Samsung didn't work with my note 4,but it charged the note 3 just fine
    10-18-2014 08:52 PM
  5. tengtengvn's Avatar
    All aftermarket adapters that I have works fine with the Note 4. 2A charger charges it at the same rate as the Note 3.
    10-24-2014 09:31 AM
  1. Cheap eBay Qi Chargers...?
    By RookM1 in forum Chargers and Batteries
    Last Post: 06-28-2015, 04:37 PM
  2. only 7 languages available on AT&T note 4? No Vietnamese?
    By sqa4life in forum Samsung Galaxy Note 4
    Last Post: 11-21-2014, 10:30 AM
  3. Why won't my Galaxy Note 3 touchscreen work with my touch?
    By GN3Ireland in forum Samsung Galaxy Note 3
    Last Post: 10-27-2014, 04:51 PM
  4. Does all countries make Note 3 screen quality the same way?
    By iain555 in forum Samsung Galaxy Note 3
    Last Post: 10-26-2014, 12:26 PM
