1. dynomike87's Avatar
    First question, I have music on iTunes and I heard there's an app to change it over to the note 4 and I can't remember the name. Also I have music on a file on my computer can I just slide that over? I feel comfortable with the phone now so what apps could I use to change icons but that's not too crazy of an app where I'd be in over my head. Thanks for the help!
    10-18-2014 06:52 PM
  2. mhunter6378's Avatar
    Samsung Kies will pull your music from iTunes or you can sync it to Google Music in the cloud to play through Google Play music. iSyncr and Double Twist are apps that sync music from iTunes to Android. Or finally, yes you can just drag and drop music from your computer to a folder on your phone and the music player will find it as long as it's not DRM protected.
    10-18-2014 06:57 PM
  3. necorbin's Avatar
    Google Play Music ftw! It will auto sync your music from iTunes, and has SO many other things you can do too!
    10-18-2014 07:06 PM
  4. bullz7210's Avatar
    I used Isyncr. Worked great
    10-18-2014 07:59 PM
  5. madmurd's Avatar
    I used some Samsung transfer software price of ****
    10-19-2014 12:08 AM
  6. Biggiefries's Avatar
    Easy phone tunes. You can find it on the google play store. Made exactly for that. I did with my old Galaxy S3 worked great!
    10-19-2014 12:19 AM
  1. Sprint Note 4 Simultaneous voice & data
    By sfrsteel in forum Samsung Galaxy Note 4
    Last Post: 04-19-2015, 09:36 PM
  2. Question about 10 GB Share
    By DSF767 in forum General Carrier Discussion
    Last Post: 10-21-2014, 01:14 PM
  3. Note 4 Display saturation in sunlight.
    By bassplayrguy in forum Samsung Galaxy Note 4
    Last Post: 10-19-2014, 06:16 PM
  4. Note 4 keyboard case
    By cjc085 in forum Samsung Galaxy Note 4
    Last Post: 10-19-2014, 04:36 PM
