09-27-2016 04:08 PM
264 1234 ...
tools
  1. TJPWX's Avatar
    I'm with those who have battery drain issues. I'm with ATT and notice the battery draining dramatically during use. Even in U Power Save mode my phone dropped 7% in 6 hours. A buddy of my with the Gs5 went an entire week on power save mode. So, I agree with others that there's something wrong.
    Also, I've noted with others that my WiFi seems to be constantly active. Arrows seems to be active constantly.
    10-19-2014 06:38 AM
  2. tarpon6's Avatar
    I'm on Sprint too and am having battery issues. Drains fast and my screen is using 33% even with it turned down. This is only an hour after I was fully charged.
    I have checked for the update but it is not available yet.
    4% in 1.25 hours is battery drain? You would be able to go 25 hours with over 6 hours screen time at that rate.. Looks ok to me..
    10-19-2014 06:55 AM
  3. Ncontrl's Avatar
    If you you look at the screenshot that you posted, where it shows "83% Charging (USB)" that means the phone is taking the charge at what it believes is from a USB port - like it would get while connected to a computer for instance. The maximum charge rate under those circumstances would be at 500mA (0.5A) from a USB 2.0 port. While charging through the AC charger plugged into a wall outlet the rate would be 2000mA (2A) approximately. Your phone is charging slowly because either there is a problem with the phone, the charger or the charger cable. Try disconnecting the cable from the phone and the charger block. Unplug the charger from the outlet that it is in. Go to a different outlet and plug everything back up and look at your battery screen again (the same one you posted the picture of above). Look where it shows the the percent and charging, see if it now says "Charging AC", if it does not try a different charger if you have one and also try a different cable too. By trying a different outlet, charger and cable you can eliminate which is causing the problem, lastly being a problem with the phone itself if different chargers, cables and outlet don't correct the issue.
    Your right on that... It should read Charging(AC) instead of Charging(USB)
    10-19-2014 07:07 AM
  4. screwhead728's Avatar
    I have a question in regards to the battery. Do you guys who have about about 15 hrs of use and 20 or more percent left on it, have the screen brightness in full? I ask this question because I like to have my screen brightness to max. Also, do you guys have location on? I have it on but the mode is on Power Saving (uses wifi and mobile network to estimate your location). Will appreciate your feedback.
    10-19-2014 07:17 AM
  5. thegame161's Avatar
    Here's mine and no never have location on unless I'm using maps
    Attached Thumbnails Why is the battery life on my Note 4 low?-1413721600263.jpg
    10-19-2014 07:27 AM
  6. Nakrohtap's Avatar
    Your screenshot shows it charging over USB. Is that the way you have been charging your phone? You do know that charging over USB will only give you a fraction of the charge rate you would get through AC charging and would take a long time to fully charge your phone. If it's taking seven hours to get a 60% charge with an AC charger then yes you have an issue, with USB charging that length of time would be expected if the phone is powered on.
    Good catch! This is definitely the issue here. USB is painfully slow.
    Sent from my SM-N900V using Tapatalk
    10-19-2014 07:35 AM
  7. mhunter6378's Avatar
    Here's mine. I always have wifi, Bluetooth, and location (high accuracy) on all the time. I take the set it and forget approach, just don't want to toggle stuff on and off all the time. I set my brightness at 50% on auto and it works fine for me. With auto turned on the brightness ramps up fine for outdoors. As you can see in the screenshot location is only turning on periodically, it does not stay on all the time. I need it for my commute times in Google Now, traffic around Atlanta is horrible. I'm usually off charger for 15 to 16 hours with no issues.
    10-19-2014 07:54 AM
  8. parscale's Avatar
    Been following this thread. Something is wrong and AT&T needs to post the update. Losing 1% every 6 minutes on average. My S5 on heavy usage is way better.
    mrstruegemini likes this.
    10-19-2014 08:11 AM
  9. Marguerite Boone's Avatar
    Thank you so very much! I guess whatever outlet I was using was faulty and therefore thinking it was charging via USB. I changed outlets and it read AC. Another question, is there any app I can get that keeps wifi off until I have it turned on? I went to bed with wifi turned off, 100% and woke up later with 95%, wifi on, and a **** ton of app notifications. Also how do I turn off push notifications? Sorry, although I am an android girl I still haven't figured out everything the note has to offer so any help is greatly appreciated.
    10-19-2014 08:16 AM
  10. vader4633's Avatar
    If you have battery issues, make sure you are not syncing to drop box or google photo back up all times. For example, I use photos to back up all my photos but in the settings I have it only back up when plugged in to the charger. Hopefully this might help someone.
    10-19-2014 08:19 AM
  11. mhunter6378's Avatar
    Open settings, tap on wifi, tap the 3 dot menu button upper right corner, tap advanced, uncheck always allow scanning, tap keep wifi on during sleep and select - only when plugged in and the exit your settings you're done. As for the notifications they will be controlled through each apps settings. Open and check the app settings for the ones that you're concerned about and see if they have a switch option for notifications. You could also go into settings, application manager, find the app in the list - tap it and on the resulting screen uncheck - show notifications. Glad to hear you got your charging issue corrected.
    Marguerite Boone likes this.
    10-19-2014 08:39 AM
  12. mick21's Avatar
    hi guys got my note 4 on friday too fully charged it then started setting up accounts and getting apps and it went down to 69% very fast went to bed and wen i woke up it was down to 28% so was very dissapointed i had a look at my setting and found in the display settings i had led indicator ticked so i unticked that fully charged it again and got 14 hours out of a full charge with screen on full brightness and mobile data on and tethering on and bluetooth on which i was inpressed by i had the original note and only got about 6 hours on the same settings. so far im happy.
    also after a full charge i went to bed and when i got up it was 94%.
    10-19-2014 08:55 AM
  13. livetoride4666's Avatar
    I've been following this thread, because battery life is important to me. I currently have a oneplus one and the battery is Amazing. I am a HEAVY user, I keep wifi, Bluetooth, everything on and I get a day and a half. I don't think with a phone the size of a note you should have to be toggling on or off settings for battery life. So far this thread is swaying me to just keep my current phone.
    Jay Sacks likes this.
    10-19-2014 09:18 AM
  14. Bizzle69's Avatar
    Ok... some of you guys need to realize that if you set up a phone, and play around with it (on top of that), the phone is working overtime - doesn't matter the device... The kernel/stock rom has to settle into the phone (sounds weird but it is 100% right on), if you're phone drains like this after a full week of use of the phone - then you should go into settings - manage applications/application manager - select Google Play Services, clear cache... then select google play store and clear cache - reboot the phone after those two steps.
    We live in a world of high expectations and little patience... just wait it out - especially if you AT&T users haven't received the update yet.
    10-19-2014 04:58 PM
  15. lazerproof's Avatar
    Not sure what that means? I am charging with the charger it came with, plugged into the wall.
    The charger that came with it is a 9v charger so you should be able to fast charge, if not something wrong. Don't expect to get anywhere the same charge times with any other charge method. As others have said, make sure that you have fast charge enabled and check for updates. I know that the day I got mine, I was prompt for an update as I was walking out of Tmo.
    10-19-2014 05:22 PM
  16. seacow1500's Avatar
    I noticed that it is different than the Note 3 charger. I have been using mine since I got it and just charged with the one that came with the phone. When I plugged it in it said something about fast charging. Never saw it with the Note 3 cord.
    10-19-2014 05:34 PM
  17. Beltelmel's Avatar
    After coming from a Lumia 920 windows phone the battery life on this N4 has been great!!!
    10-19-2014 06:09 PM
  18. mrstruegemini's Avatar
    I got my Note 4 Friday also. the battery life has been so crappy. My first problem was my apps wouldn't download. I had to restart it a few times before they started to download. I have AT&T it's been freezing and I have to take the battery out to get it to reboot. I even tried waiting like 20 mins before removing the battery. Then AT&T ready to Go keeps popping up randomly. Im pretty tech savy and awesome with devices. I took 40 + pics at a wedding yesterday and only like 11 are viewable they rest are shady gray squares and none of the videos work. I fully charged the battery multiple times including before use. I have turned off background data which seem to help today. All location info is off that helped. I turned the screen brightness down and put it on power save. I then turned off AT&T apps that can preloaded that were running in the background it helped. But it's still not good. My daughter got the Samsung Galaxy S5 also she's a heavy phone user and after being gone all day to the wedding taking pics videos she charged one time to my 3 times yesterday. Today she's been on it all day and she hasn't charged at all since 8 am and battery is still at 75 %. I'm so annoyed right now. I did some research and found that Nexus users are also complaining about the exact same thing. Because of other issued I'm exchanging the phone in the morning. Forgot: including since 11 am Friday I have been removing the battery 2-3 times daily for freezing. When I say freezing I mean it doesn't respond to any touch or button pressing soft resetting for over 15-20 mins at times an hour plus. It's a new device I've already factor reset and not doing it again
    10-19-2014 07:09 PM
  19. lazerproof's Avatar
    Looks like you have a bad phone.
    10-19-2014 07:16 PM
  20. bassplayrguy's Avatar
    I'm on ATT and don't have bad battery life at all. I lose about 2-3% an hour.
    10-19-2014 07:17 PM
  21. DETERMINOLOGY's Avatar
    u must be barely touching your phone
    10-19-2014 07:22 PM
  22. Wolvan's Avatar
    The first day I picked it up it came at around 50% and it dropped fast. But once I did the first full overnight charge its been great. Not heavy use but a fair bit of pictures and videos at the pumpkin farm today. Yesterday was similar with heavier use.
    Attached Thumbnails Why is the battery life on my Note 4 low?-1413764580887.jpg
    drew_dixon likes this.
    10-19-2014 07:23 PM
  23. KingTongue's Avatar
    Amazing battery life for me. Went a whole day without charging.
    Posted via My Note 4
    10-19-2014 07:34 PM
  24. sillehrabbitz's Avatar
    First day when I was tinkering with everything it got me through the day. Now it has lasted yesterday and pretty much most of today. I am pretty impressed so far.
    10-19-2014 07:40 PM
  25. vinnyvin's Avatar
    Lol I remember those days
    10-19-2014 08:51 PM
264 1234 ...
  1. Can anyone help with battery problems I am having on my generic tablet?
    By oslash in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 09-19-2016, 08:59 AM
  2. Can anyone help with Rooting a Galaxy Note 8 with Kitkat?
    By CKR83 in forum Samsung Galaxy Note 8.0 Tablet
    Last Post: 11-25-2014, 10:11 PM
  3. Replies: 5
    Last Post: 10-20-2014, 05:56 PM
  4. Note 4 S note features that has been taken away..
    By honey_bee_33 in forum Samsung Galaxy Note 4
    Last Post: 10-19-2014, 02:37 AM
  5. Editors "What's On My Phone"
    By flybub in forum Site Feedback & Help
    Last Post: 10-18-2014, 07:02 PM
