09-27-2016 05:08 PM
264 ... 34567 ...
tools
  1. jdhooghe's Avatar
    So here is wake lock detector on my nexus 7. I made the mistake of going into Google wallet earlier and here is the result. Nlp woke my device up 257 times between then and now. OP, please try the same.
    10-25-2014 04:55 AM
  2. ansa82's Avatar
    Mine is fabulous! Yesterday I activated at 8am. By 9:30 pm I was down to 26%. That was heavy use with downloading apps & checking the phone out. My note 3 wouldn't have lasted that long
    10-25-2014 08:15 AM
  3. daniel kramer's Avatar
    I have the same problem whith my sprint note 4 in less then one hour im down to 80% from 100%
    10-27-2014 07:43 AM
  4. brick58's Avatar
    my directv app is taking up 30% I did a force stop and now it is at 28% maybe I should just delete the app? also am on att and android newbie...how do I post screenshots to this site? thanks
    barb
    10-27-2014 10:09 AM
  5. Almeuit's Avatar
    barb
    Are you using the DirectTV app?
    10-27-2014 10:26 AM
  6. brick58's Avatar
    not at the present time
    10-27-2014 10:30 AM
  7. Stephen Martino's Avatar
    The app will continue to show as it was using the battery until you plug in and recharge. I notice from time to time an app seems to be using up the battery for no reason. A reboot usually resolves the issue.
    Almeuit and brick58 like this.
    10-27-2014 10:34 AM
  8. Ed LaJoie's Avatar
    The battery life on my Note 4 has been really good so far.
    10-27-2014 10:37 AM
  9. Almeuit's Avatar
    This. If you use an app it is going to show up in the battery usage. Such as when I stream Google Music with the screen off during work -- the two things showing the most usage are the Google Music app and the Bluetooth for my headphones... This is due to those apps being the main cause of the drain on the battery. It makes sense though since I am using them for music.
    brick58 likes this.
    10-27-2014 10:55 AM
  10. inffy's Avatar
    Lot of battery problems here . See the screenshot
    What could be the problem ?
    Attached Thumbnails Why is the battery life on my Note 4 low?-uploadfromtaptalk1414423346046.jpg   Why is the battery life on my Note 4 low?-uploadfromtaptalk1414423357103.jpg   Why is the battery life on my Note 4 low?-uploadfromtaptalk1414423367535.jpg   Why is the battery life on my Note 4 low?-uploadfromtaptalk1414423379520.jpg
    10-27-2014 11:23 AM
  11. JK0907's Avatar
    I'm new to Android/touchwiz world, as I switched from Windows Phone. Can anybody advise me if there are any preinstalled bloatwares that I need to remove that might use the battery? Thanks.
    10-27-2014 12:22 PM
  12. inffy's Avatar
    You can't remove the preinstalled bloat ware without root
    10-28-2014 01:05 AM
  13. mcdonsco's Avatar
    So far I have not been impressed with the battery life on the note 4, so much so I had Verizon swap the phone out for a replacement yesterday...so far, not much of a difference.
    I'm starting to wonder if something changed with the towers in my area causing my phone to struggle to keep a signal...?
    Only thinking that because my last phone also had battery life issues (lg g2)...and I usually hover around 2 bars 4g...always have in this house.
    If I could buy the Samsung battery kit I wouldn't be too concerned, one of the reasons I got the phone, but always takes Samsung months to release those accessories.
    10-28-2014 10:09 PM
  14. Katrina White1's Avatar
    I have Sprint and I think my battery is fine. So far, the most I got was 1 day, 1 hour with 6:18 screen on time. Light use during work hours, heavier at night. Right now I have 9hr 50 min with 4hr 16 min screen on.
    10-28-2014 10:34 PM
  15. inffy's Avatar
    I have no glue how does someone get over 6h of screen on time. I hardly get 3 hours and I don't even use the device much. Android system and android os are the biggest battery consumers for me
    10-29-2014 10:32 AM
  16. Austin Erikson's Avatar
    I am also having battery life problems. My screen is using 37% of the battery (the next two largest battery uses are android system (18%) and android os (9%)), but yet I have screen timeout set at 30 seconds and I use auto brightness. I've used all of the recommendations to extend battery life, I use power saving mode, I clear my cache very frequently, I always close the apps that I use immediately, and I make sure to use ultra power saving mode if I know I won't be using the phone much. Despite all of my efforts, the battery life is still worse than my galaxy s4. I've turned off as many Google services as I can think of (including "Okay Google" and Google Now), and I don't use Bluetooth, location, or GPS. I'm barely using it for videos or music, but yet I am still getting poor battery life. Does anyone know what I can do to decrease screen battery usage and to increase the overall battery life? Thank you!
    10-31-2014 01:12 AM
  17. rgriffin25's Avatar
    I'm on my 3rd Note (2,3,and 4). Generally I have had pretty good battery life with the Note series. The Note 4 has been far superior to the other phones. I usually buy the spare battery charger and was disappointed to see it was back ordered. Now that I've used the phone for 2 weeks I'm certain I can save money by not buying the extra battery. Today I had moderate usage with over an hour playing music while driving, using the flashlight for around 30 minutes, brightness set to 40%. Not using power saving mode I am at 33% after approx 17 hours since I took it off of the charger. I'm on Att with decent coverage.
    10-31-2014 01:26 AM
  18. yeatzee's Avatar
    I came into the note line with high expectations, and so far I've been fairly pleased with my battery life. It is clearly far superior to any other phone I've personally used, but that isn't necessarily saying much. I've chronicled each day since I picked it up and it seems that 6 hours of screen on time is the sweet spot, however long it takes to reach that mark is how long the battery will last for the most part. The great thing for me has been that yes the battery lasts a good while, but it also charges insanely fast. I can throw it on the charger and go eat some dinner and afterwards have more then enough battery % to get me through an all nighter if I wanted. Anyways here's my results.
    edit: in the preview it listed them as being shown side by side, sorry about elongating the page.
    Attached Thumbnails Why is the battery life on my Note 4 low?-screenshot_2014-10-25-02-06-35.jpg   Why is the battery life on my Note 4 low?-screenshot_2014-10-25-02-06-40.jpg   Why is the battery life on my Note 4 low?-screenshot_2014-10-25-21-00-47.jpg   Why is the battery life on my Note 4 low?-screenshot_2014-10-25-21-00-52.jpg   Why is the battery life on my Note 4 low?-screenshot_2014-10-28-00-15-15.jpg
    Why is the battery life on my Note 4 low?-screenshot_2014-10-28-00-15-26.jpg   Why is the battery life on my Note 4 low?-screenshot_2014-10-28-21-00-32.jpg   Why is the battery life on my Note 4 low?-screenshot_2014-10-28-21-00-39.jpg   Why is the battery life on my Note 4 low?-screenshot_2014-10-30-02-12-46.jpg   Why is the battery life on my Note 4 low?-screenshot_2014-10-30-02-12-53.jpg
    10-31-2014 02:46 AM
  19. criffaaa1's Avatar
    Why is the battery life on my Note 4 low?-uploadfromtaptalk1414741820042.jpg
    Why is the battery life on my Note 4 low?-uploadfromtaptalk1414741849866.jpg
    I have the sprint N4 and get awesome battery life.
    10-31-2014 03:52 AM
  20. yeatzee's Avatar
    I'd say so, those look like the most ridiculous numbers I've heard of yet. How you managed 8 hours of screen on time is beyond me (though it shows it jumped from a low % to ~100% and doesn't climb like with regular charging so did you swap batteries? If so it would seem that at least an hour of battery time [and screen on time?] would be taken off considering the chart is ~20 hours of time condensed). Im impressed, any suggestions?
    10-31-2014 03:57 AM
  21. Zergslayer69's Avatar
    Makes you wonder how those reviewers managed to get the 12+ hour video playback test. Just getting more than 6 hours of screen time is amazing.
    10-31-2014 10:30 AM
  22. Almeuit's Avatar
    Which carrier version do you have? T-Mobile received a battery fix update -- I don't think the other carriers have released it yet.
    10-31-2014 10:40 AM
  23. screwhead728's Avatar
    I always turn off the Wi-fi as soon as I leave the house. I also have Bluetooth off, Media Server off, GPS off, NFC off and I get EXCELLENT battery usage every day. I don't have Power Saving mode on and I have the brightness at 100%. I'm a heavy user. I listen to ESPN Radio every day at work, probably for a good 3-4 hours in total, Instagram, Facebook, YouTube, Flipboard, e-mails, and probably a few web sites here and there. Leave the house at 7:30 AM with 100% and when I get home, I have 45-50% around 5:30 PM, meaning I can definitely go a day without charging. The carrier also matters and BIG time. I used to have Sprint before, I recently moved to At&t and now I can finally say that I get to enjoy my phone. Sprint's network sucks so much that your phone's battery drains looking for signal, downloading, etc. So it also depends on the carrier.
    10-31-2014 10:44 AM
  24. Almeuit's Avatar
    Brightness 100%? Ouch. I would be blind haha :P.
    10-31-2014 10:47 AM
  25. criffaaa1's Avatar
    No battery swap involved, I did however let the phone die completely before I charged it. I turned it on at 99% checked the battery stats and grabbed a quick screenshot. Although its been said you don't need to power cycle the batteries I still do it. I'll go from 100% and let it run till the phone completely dies before I recharge. I actually ran VEVO for 3 or 4 hours to kill the battery so I could recharge.
    10-31-2014 11:15 AM
264 ... 34567 ...
  1. Can anyone help with battery problems I am having on my generic tablet?
    By oslash in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 09-19-2016, 09:59 AM
  2. Can anyone help with Rooting a Galaxy Note 8 with Kitkat?
    By CKR83 in forum Samsung Galaxy Note 8.0 Tablet
    Last Post: 11-25-2014, 11:11 PM
  3. Replies: 5
    Last Post: 10-20-2014, 06:56 PM
  4. Note 4 S note features that has been taken away..
    By honey_bee_33 in forum Samsung Galaxy Note 4
    Last Post: 10-19-2014, 03:37 AM
  5. Editors "What's On My Phone"
    By flybub in forum Site Feedback & Help
    Last Post: 10-18-2014, 08:02 PM
