09-27-2016 05:08 PM
264 ... 56789 ...
tools
  1. Naramis's Avatar
    My battery life is terrible. Exynos version.
    Right now I have 29 minutes of screen on time and the battery is already at 70%. I can't figure out what is spending so much battery.
    After the screen, what is spending energy is "Android System", "Android OS", "Battery standby" and "Inactive device". I can't figure out which application is spending so much. And the phone gets a bit hot when it's in my pocket doing nothing.
    I haven't installed many applications, in fact I even uninstalled a lot of the ones that came with it. Please halp, how can I find out what is spending my battery?
    11-13-2014 12:52 PM
  2. philip42's Avatar
    Not sure if this has already been mentioned but on my S4 I Unselected the option in wifi settings to allow Google wifi scanning at all times even while wifi is turned off. It was eating my battery every night. Battery improved dramatically when I switched it off. Turned it off on my Note 4 now too.
    11-13-2014 01:12 PM
  3. getdez's Avatar
    Android System and Kernel eating up my battery today as well. Android system is @ 22% leading battery drainer.
    11-13-2014 01:32 PM
  4. rosenbluu's Avatar
    Not sure how to post pictures but I'm not getting no where near the on screen time as everybody here... I'm at 4 hours of on screen time with 9% battery...
    11-13-2014 09:59 PM
  5. rosenbluu's Avatar
    With my on screen time taking 45% of the battery drain.. help!!
    11-13-2014 10:00 PM
  6. LaTuFu's Avatar
    Where do you have your screen brightness set?
    11-14-2014 05:40 AM
  7. rosenbluu's Avatar
    Always have my screen brightness on auto
    11-14-2014 07:34 AM
  8. LaTuFu's Avatar
    Maybe try keeping it on manual for a day or two. Adjust it down until it's just bright enough to read indoors. For me, that is usually 10-20% (almost all the way to the left). I have found auto will increase CPU usage, as well as adjust the brightness more than necessary for me.
    I can't claim that it is the problem, but it might help.
    11-14-2014 08:12 AM
  9. rosenbluu's Avatar
    Trying this right now, I'm at 59% with 1h 20 minutes of on screen time... why is this so horrible?
    11-14-2014 12:47 PM
  10. hdhuntr's Avatar
    Try what I said in post number 151. Right next to what you said here.
    11-14-2014 01:10 PM
  11. getdez's Avatar
    I installed GSAM but if the thing just says Android System and Kernel are hogging up battery how can you determine from there what the cause or specefic app is?
    11-14-2014 01:20 PM
  12. tivoboy's Avatar
    My battery life is VERY good easily best phone I have ever had. I get usually 1.5-2 DAYS of battery before the 5% dimmed screen.
    11-14-2014 07:09 PM
  13. Halofury's Avatar
    My battery life had been awesome until the past 2 days...
    Attached Thumbnails Why is the battery life on my Note 4 low?-screenshot_2014-11-14-21-39-14.jpg
    11-14-2014 10:40 PM
  14. debsawyer's Avatar
    Make sure you file a complaint on their Facebook page.
    11-14-2014 11:24 PM
  15. divineazn716's Avatar
    Are you using the stock wall charger that comes with it? Or a different one. The cord is usually always a problem if its a cheap bootleg one.
    I am having battery life issues as well. I have data turned off and have only been using wifi. My screen brightness is auto and I have fully charged my phone up to 100% twice. During charge, I keep my phone sleeping. At 2:20 today, my phone was at 20% so I began to charge it. It is now 9:39 and I am at 80%!! Wifi has been off since charging, and i have only texted a few times..power saving mode is on as well but It doesnt seem to be doing anything. Someone please help me! What am I doing wrong?!
    BTW fast charge is checked off! It is just grayed out (I cannot uncheck it)
    11-16-2014 03:04 PM
  16. tbolt86's Avatar
    I'm on T-Mobile i can get anywhere from 10-14 hrs depending how heavy i use it and im a pretty heavy user. No complaints way better than my note 3 which i had to keep by the charger all day cause it would die in like 4 hrs. Also bat only goes down 3% from being unplugged for 8 hrs while i sleep
    P.s. android system and os is always 20%+ for me
    Sent from my Galaxy Note 4
    11-16-2014 10:20 PM
  17. thegame161's Avatar
    those getting bad battery life is this on wifi or just 3G/4G?
    11-16-2014 10:53 PM
  18. Whipped99's Avatar
    Try killing the Samsung quick connect app and the Samsung updates app in the background running applications. This helped my battery drain significantly.
    I had the android index running 40% prior to killing the above mentioned apps and the phone would get pretty warm. Anytime you have an application eating more than the screen there's something wrong...
    11-16-2014 11:22 PM
  19. tivoboy's Avatar
    this is getting pretty common for me on this phone, best battery of ANY phone I have ever used..
    Attached Thumbnails Why is the battery life on my Note 4 low?-screenshot_2014-11-11-18-25-16_resized.png
    debsawyer likes this.
    11-17-2014 02:44 PM
  20. tbolt86's Avatar
    Holy crap how???
    TechNut79 likes this.
    11-17-2014 03:19 PM
  21. varunaX's Avatar
    you shouild post a screenshot of your screen time for those 48 hours
    11-17-2014 03:47 PM
  22. tivoboy's Avatar
    doesn't the image show screen time 13%?
    what is interesting is, I have three GMAIL accounts (the bulk of emails) and two MAIL accounts (using the stock app) both which are IMAP, with I think 15 or 30 min sync's but they get mail immediately similar to PUSH, but I don't know where that setting is - and yet, the MAIL doesn't even show up as battery usage top 10
    11-17-2014 03:58 PM
  23. rosenbluu's Avatar
    Alright so I was getting about 3.5 hours of on screen time. Few things I did and I'm at 58% right now with 2.5 hours on screen...
    1. Use the charger the phone came with
    2. Let your phone die completely and then charge.
    3. Turn your screen brightness off auto and adjust accordingly, I'm mostly 10-20% from the left when I'm inside
    Not sure if this is what solved my issue but one of these things helped if not all..
    Also I think your mobile connection will also affect your battery life
    11-17-2014 03:59 PM
  24. tivoboy's Avatar
    My brightness is about 50%, it seems that there is VERY LITTLE difference between about 40-60%, it just doesn't show up much change - so might as well err on the low side.
    11-17-2014 04:13 PM
  25. debsawyer's Avatar
    How are you getting this? My Gmail is using 24%.
    11-17-2014 06:40 PM
264 ... 56789 ...
  1. Can anyone help with battery problems I am having on my generic tablet?
    By oslash in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 09-19-2016, 09:59 AM
  2. Can anyone help with Rooting a Galaxy Note 8 with Kitkat?
    By CKR83 in forum Samsung Galaxy Note 8.0 Tablet
    Last Post: 11-25-2014, 11:11 PM
  3. Replies: 5
    Last Post: 10-20-2014, 06:56 PM
  4. Note 4 S note features that has been taken away..
    By honey_bee_33 in forum Samsung Galaxy Note 4
    Last Post: 10-19-2014, 03:37 AM
  5. Editors "What's On My Phone"
    By flybub in forum Site Feedback & Help
    Last Post: 10-18-2014, 08:02 PM
