09-27-2016 04:08 PM
264 ... 678910 ...
tools
  1. sdlakerfan8's Avatar
    The screen percentage isn't just the display brighteness. It takes into account how often you are on your phone......you know, the power to illuminate the screen and keep it going so you can use your phone.....that sort of thing. I'm going down about 4% an hour, too.
    11-20-2014 04:12 PM
  2. currentdroiduser's Avatar
    doesn't the image show screen time 13%?
    what is interesting is, I have three GMAIL accounts (the bulk of emails) and two MAIL accounts (using the stock app) both which are IMAP, with I think 15 or 30 min sync's but they get mail immediately similar to PUSH, but I don't know where that setting is - and yet, the MAIL doesn't even show up as battery usage top 10
    So that's 6 hours 24 mins on screen time
    11-20-2014 06:44 PM
  3. chevyman29's Avatar
    Why is the battery life on my Note 4 low?-screenshot_2014-11-20-23-40-48.jpgWhy is the battery life on my Note 4 low?-screenshot_2014-11-20-23-41-01.jpgWhy is the battery life on my Note 4 low?-screenshot_2014-11-20-23-41-09.jpg
    Best battery life of any phone I've ever had period. Even beats my Droid maxx.
    skatergirl likes this.
    11-20-2014 11:52 PM
  4. varunaX's Avatar
    chevyman, you are gonna get a lot of jealous posts after posing those numbers asking how you get those. seems too good to be true
    11-21-2014 08:47 AM
  5. skatergirl's Avatar
ID:	149555Click image for larger version.
ID:	149556Click image for larger version.
    Chevyman, I just went to the Note from the Droid Maxx. I am getting pretty good battery life on my Note, but not as good as you.
    11-21-2014 11:19 AM
  6. chevyman29's Avatar
    Well I've turned off every bloat app that I can or that I don't use. Plus I use a black wall paper that I think helps. And I use auto brightness that works perfect for me. On the other hand I never use wifi and I always use blue tooth ear piece. Plus I'm running art. But I was getting great battery life before art.
    11-22-2014 02:10 AM
  7. tbolt86's Avatar
    Art?
    Sent from my Galaxy Note 4
    11-22-2014 02:14 AM
  8. currentdroiduser's Avatar
    No wifi helps what bloat apps u disabled
    11-22-2014 02:20 AM
  9. chevyman29's Avatar
    Art?
    Yes ? Art run time instead of delvick.
    11-22-2014 02:40 AM
  10. chevyman29's Avatar
    That's my point. I don't use wifi.
    I don't really have a list of app I've turned off.
    11-22-2014 02:42 AM
  11. tbolt86's Avatar
    Post a screen shot of the list of apps u have disabled in application management
    11-22-2014 02:53 AM
  12. chevyman29's Avatar
    11-22-2014 03:33 AM
  13. tbolt86's Avatar
    Holy bloat tmobile has almost none of those apps
    11-22-2014 08:27 AM
  14. chevyman29's Avatar
    LOL at least its able to be turned off
    tbolt86 likes this.
    11-22-2014 12:18 PM
  15. kanesmith41's Avatar
    What is Unified Daemon?
    USMC97
    11-22-2014 05:26 PM
  16. sbhatia1981's Avatar
    USMC97
    Something to do with weather widget, you won't be able to get weather widget with that disabled, I greenify so can use widget too.
    kanesmith41 likes this.
    11-22-2014 05:38 PM
  17. Naramis's Avatar
    Wow, 5+ hours of screen on time? I get 2h45 - 3h and then my battery is at 5%.. I'm really beginning to think something's wrong with my unit..
    11-23-2014 07:17 AM
  18. Intelwin's Avatar
    Im also experiencing low battery life for Note 4. I dont use the phone for sms and calls, i do very minimal browsing using mobile data. i play an online game for about 3 times per day, 10-20 mins more or less. I listen to music.. but i only get a screentime of maximum 3 hours. Is there somthing wrong with my device or the battery?
    Thanks!
    11-25-2014 11:49 PM
  19. tbolt86's Avatar
    The best i got so far 17hrs
    11-25-2014 11:49 PM
  20. Intelwin's Avatar
    what activities do you normally do? do you use the power saving mode?
    thanks!
    11-25-2014 11:57 PM
  21. tbolt86's Avatar
    No and it depends normally it lasts me 10-12 hrs of very heavy use im on instagram constantly and texting mostly and family guy and simpson games now and then. Sometimes some web browsing. And i use clean master to check cpu for any lagging apps and to boost cpu and the more i stay off the phone the more battery i get lol i get between 10-14 depending how heavy i use it
    11-26-2014 12:00 AM
  22. Intelwin's Avatar
    wish mine would have the same performance as yours. not sure if it's busted or something..
    11-26-2014 12:11 AM
  23. JayNote's Avatar
    Currently on 61%.. 15 hours 32 min since unplugged, 2 hours on screen time. UK exynos version
    11-26-2014 12:21 AM
  24. hdhuntr's Avatar
    So many threads, so many answers. Apps like GSAM. Almost none of the phones are "busted".
    11-26-2014 12:29 PM
  25. Naramis's Avatar
    Gsam didn't seem to add any information other than what's already available in the settings... Am I missing something?
    11-26-2014 07:59 PM
264 ... 678910 ...
  1. Can anyone help with battery problems I am having on my generic tablet?
    By oslash in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 09-19-2016, 08:59 AM
  2. Can anyone help with Rooting a Galaxy Note 8 with Kitkat?
    By CKR83 in forum Samsung Galaxy Note 8.0 Tablet
    Last Post: 11-25-2014, 10:11 PM
  3. Replies: 5
    Last Post: 10-20-2014, 05:56 PM
  4. Note 4 S note features that has been taken away..
    By honey_bee_33 in forum Samsung Galaxy Note 4
    Last Post: 10-19-2014, 02:37 AM
  5. Editors "What's On My Phone"
    By flybub in forum Site Feedback & Help
    Last Post: 10-18-2014, 07:02 PM
