If you you look at the screenshot that you posted, where it shows "83% Charging (USB)" that means the phone is taking the charge at what it believes is from a USB port - like it would get while connected to a computer for instance. The maximum charge rate under those circumstances would be at 500mA (0.5A) from a USB 2.0 port. While charging through the AC charger plugged into a wall outlet the rate would be 2000mA (2A) approximately. Your phone is charging slowly because either there is a problem with the phone, the charger or the charger cable. Try disconnecting the cable from the phone and the charger block. Unplug the charger from the outlet that it is in. Go to a different outlet and plug everything back up and look at your battery screen again (the same one you posted the picture of above). Look where it shows the the percent and charging, see if it now says "Charging AC", if it does not try a different charger if you have one and also try a different cable too. By trying a different outlet, charger and cable you can eliminate which is causing the problem, lastly being a problem with the phone itself if different chargers, cables and outlet don't correct the issue.
