1. dustout's Avatar
    Is there a known way to get multi window to work with Netflix on the Note 4? That was probably the thing I was most excited about and sadly it does not seem to natively support doing that...
    10-20-2014 01:25 AM
  2. reesh11's Avatar
    If it's not in that list when you hold down the back button then probably not. You may be able to make it one of those smaller windows though I'm not sure.
    From my smokin' hot N4
    10-20-2014 01:40 AM
  3. inffy's Avatar
    Not possible to multiwindow Netflix
    10-20-2014 01:50 AM
  4. fragologist's Avatar
    Is it possible to watch Netflix on your Web browser. If so then you can use the multi Window.
    10-20-2014 07:47 AM
  5. boufa's Avatar
    Try https://play.google.com/store/apps/d...iwindow.enable
    It tries to insert the metadata into the app that triggers multi window compatibility. I have had some success with it. The version I linked to is the free version and it will only do pop up windows. However IF the pop up window works for you, then you can pay for the full version ($2.50 I think) and it will do the multi window thing too.
    A few notes... its flakey and not every app likes multi window. Waze worked great in multi window on my N2, doesn't work on my N4. I have a couple of programs that it works fine for. Also, you MUST go into the play store app and turn off auto update for any app that you modify with this program. If the app updates its self you lose the multi window features.
    I did use Netflix on my N2 with multiwindow from time to time, so it might work for you.
    canonBoy likes this.
    10-20-2014 07:49 AM
  6. dustout's Avatar
    Thank you boufa! That worked for getting Netflix into a window. Very fast and easy. It seems to scale it down nicely too so the high DPI of the screen makes it hella sharp.
    Sadly whenever Netflix loses focus it pauses the show. Clicking back into Netflix lets you unpause. This at least lets me quickly switch between watching and doing other stuff. Thank you very much for recommending that app.
    There's one oddity if anyone else does this but I have a workaround. Sometimes it gets stuck in vertical even though the phone is horizontal. If you need to get Netflix to switch into horizontal mode (it seems to get stuck in vertical sometimes when rotating) you can open another horizontal app (I open the Gmail app) and it tricks it into rotating.
    10-21-2014 03:34 AM
  7. thatdarnpunk's Avatar
    Maybe they will add multi window for it in an app update. With android l moving towards multi window we might start seeing more apps in general have this capability
    10-21-2014 06:11 AM
  1. my note 3
    By dipkid in forum Verizon Samsung Galaxy Note 3
    Last Post: 10-23-2014, 07:56 PM
  2. What would it cost to fix water damage in s4?
    By kphtaco94 in forum Samsung Galaxy S4
    Last Post: 10-23-2014, 12:32 AM
  3. Replies: 6
    Last Post: 10-20-2014, 11:19 PM
  4. Replies: 11
    Last Post: 10-20-2014, 09:42 PM
  5. Why am I not able to select any ringtones on my Moto G?
    By Vibhav05 in forum General Help and How To
    Last Post: 10-20-2014, 08:38 AM
