11-27-2014 03:16 AM
88 ... 234
tools
  1. lv2bsilly's Avatar
    The Qi charging back in white is finally in stock on the Samsung site for those of you who still haven't used your 50% off coupon! Just ordered mine . Hopefully it won't add too much bulk and still fit with my current cases.
    Galaxy Note ® 4 Wireless Charging Qi Cover, FROST WHITE
    11-24-2014 01:47 PM
  2. mhettrich's Avatar
    Ordered the Qi charger in black for my Note 4. Of course they sent me one for a Note 3. Ughh.
    11-24-2014 02:09 PM
  3. brentj's Avatar
    Received mine today. It's very well made.
    It does add a bit of bulk, but I find it fits my hand better now. I don't use a case.
    http://i251.photobucket.com/albums/g...8_134401-1.jpg
    That looks significant. On the plus side, the camera lens glass is now recessed and thus protected. The flash and heart-rate reader are considerably recessed. I may try the eBay add-on route with the standard back cover.
    11-24-2014 02:29 PM
  4. carsonx's Avatar
    I just received mine today...In black. Works great, adds a little bulk, but really not bad..I'm talking minimal. The only problem I have is my two cases no longer fit. One is a Speck rubber case from verizon and the other is a Ghostek 2 piece case I purchased off of Amazon. The Speck case I cant even get to cover the phone at all. The Ghostek, I can get on, but I cant use the top piece as the phone is now just a little to thick and the top piece will not snap down as the rubber inside is pushed to far out. Just a heads up...If you purchase a back cover, you're going to have to go without a case for awhile.
    11-24-2014 05:51 PM
  5. biggunspaul's Avatar
    So it adds size to the phone,it charges far slower than the standard charger and you have to pay extra for this.
    What were the benefits of this again lol
    11-24-2014 07:40 PM
  6. ChemMan's Avatar
    Are we still talking about plugging the phone up or something else? Attachment 146149
    Yes
    hehehe
    11-24-2014 07:45 PM
  7. varunaX's Avatar
    I have the official back and while tight, I have a caseology case that fits and charges wirelessly okay.
    Attached Thumbnails Samsung Galaxy Note 4 Wireless charging on the way!-1416876345450.jpg
    tylerjames09 likes this.
    11-24-2014 07:46 PM
  8. tylerjames09's Avatar
    Can I get a link to the case you have? Thanks
    11-25-2014 12:29 AM
  9. varunaX's Avatar
    Sorry I don't have a link cause it was given to me. But it's a caseology brand with a small diamond pattern on the back
    11-25-2014 07:15 PM
  10. ChemMan's Avatar
    Samsung Galaxy Note 4 Wireless charging on the way!-20141126_081411-1-.jpgSo it took a while but this morning I received my wireless charge mat. It came with a tempered glass screen protector, a bonus I guess because it took so long. Put in in place then put on and snapped the old Note 4 cover back on and had a slight, barely noticeable bulge on the back. Put on the charging pad and figured out where the sweet spot for charging was. Put back on the i-Blason cover and it fits fine. Put it on the pad and charges fine.
    Woohoo!
    11-26-2014 01:33 PM
  11. harryhoudini66's Avatar
ID:	150768So it took a while but this morning I received my wireless charge mat. It came with a tempered glass screen protector, a bonus I guess because it took so long. Put in in place then put on and snapped the old Note 4 cover back on and had a slight, barely noticeable bulge on the back. Put on the charging pad and figured out where the sweet spot for charging was. Put back on the i-Blason cover and it fits fine. Put it on the pad and charges fine.
    Woohoo!
    You may not care but your NFC no longer will work.
    11-27-2014 12:31 AM
  12. soldier45's Avatar
    Got mine today works perfectly but adds bulk to the phone over the standard back. About 1/8 inch more thickness.
    11-27-2014 01:33 AM
  13. harryhoudini66's Avatar
    I went overboard and got two regular Qi backs and two S VIew Qi backs. I am keeping the black one for me and sending the others so I can get the white S View when it comes out.
    11-27-2014 03:16 AM
88 ... 234
  1. Google Nexus 6 vs Samsung Galaxy Note 4
    By blueyzfr6 in forum Phone Wars
    Last Post: 05-21-2015, 10:11 PM
  2. Replies: 4
    Last Post: 10-22-2014, 01:57 AM
  3. Replies: 2
    Last Post: 10-22-2014, 01:05 AM
  4. Replies: 3
    Last Post: 10-20-2014, 11:31 PM
  5. Why are all my sounds muting randomly?
    By janban34 in forum Samsung Galaxy S4
    Last Post: 10-20-2014, 08:38 PM
