hdhuntr
Thank you lost and luv for the reviews. I am eager to see how it compares to the one I had for the Note 3 which was great. Also to see the difference between the pad that comes with it and the Koolpad I had with the Note 3 which might be better than the pad with this one. Koolpad was great and worked through my Spigen case. Not using a case on the GN4 so far.
Koolpad is $24 on Amazon Prime but it's good.
https://www.amazon.com/gp/product/B...ag=hawk-future-20&ascsubtag=UUacUvbUpU4017528
