12-06-2016 09:26 PM
143 ... 23456
tools
  1. goodwitwood's Avatar
    Tagged for interest in fix.
    Note 4
    2012 Kia Optima
    11-26-2014 07:00 AM
  2. trumee's Avatar
    I have a 2014 Corolla LE ECO and my notifications are delayed when displaying on my dashboard display. It takes 5-10 seconds for it to display on the screen after I received a text on my phone. Also, sometimes display shows the wrong song and regardless how many times I change it, it stays on the one song.
    Do you have these issues?
    Can you let me know what software version is your radio?
    My radio's software version is BU.30.05
    11-26-2014 09:07 AM
  3. EvilHomer3k's Avatar
    Unfortunately, I'm not going to be any help to you. I disable S-Voice on my Galaxy devices. I use OK Google and that's pretty much it.
    When I connect to BT on my vehicle, the only voice commands I use are with the vehicle's system, not my phone.
    I got it working a little better. I can now reply to and initiate texts with the uConnect system. Unfortunately, I can only create precreated messages with uConnect. I think I may be able to do free form messages if I subscribe to their $15 per month cloud based voice system.
    11-28-2014 10:43 PM
  4. Starla1067's Avatar
    I don't have a problem with my music, but cannot pair my Note 4 phone with my 2011 Camry bluetooth.
    12-01-2014 08:39 PM
  5. Carol Giese1's Avatar
    I have a 2012 Outback PZEV and my bofriends Iphone pairs fine.
    Not my Note 4, Says it's paired - but wouldn't connect.
    I had nothing until I downloaded the "auto connect" app.
    Now it works sometimes - and sometimes I hear it ring - won't answer and sends caller directly to voice mail.
    If it doesn' t get fixed soon - I've got til 15 Jan to return the phone. I will return it!
    12-02-2014 01:46 PM
  6. kgeier82's Avatar
    Also noticed occasionally songs stop playing for a brief second and continue. Locally cached
    12-05-2014 08:18 AM
  7. LaTuFu's Avatar
    The problem is not with your phone, it is with the firmware on your Outback's system. The iPhone uses an older BT codec that is compatible with the system. Your Note 4 does not. Contact your dealer and see if they have a firmware update available for the sound system. You may even need to research this on your own on a Subaru owner's forum, as the dealerships aren't always great about researching small details like that.
    12-05-2014 09:24 AM
  8. Mr.Gadget's Avatar
    Try deleting it from the deck and re pairing it. That helped for me. The real help was to factory reset my Note 4. It still has BT issues but at least I can auto connect without powering the phone on every time I get in the car...
    12-05-2014 12:51 PM
  9. Andrew McGrath's Avatar
    I have the Note 4 and a 2012 Subaru Impreza.
    My old HTC One M8 connected flawlessly but the Note 4 requires me to manually connect it most of the time and is generally just inconsistent when connecting, sometimes taking a few seconds to connect while other times taking 20-30 seconds after 1-2 connection attempts. It is very annoying and this is the type of thing that would make me want to return the phone.
    Is there any fix in sight?
    12-06-2014 04:21 PM
  10. Tanooki2's Avatar
    I have a 2014 BMW X1 and my Note 2 worked perfectly with it. My Note 4 will make and receive calls, but it won't play any music. It shows in the display that it's set up for audio playback, so I'm puzzled. I can't imagine a 2014 car would already need a BT firmware update. I will try unpairing and repairing.
    AntaeusX25 likes this.
    12-07-2014 05:57 PM
  11. LaTuFu's Avatar
    It's very possible. Even new generation models will sometimes incorporate older generation parts.
    My 2011 Jeep had the same radio that was in my wife's 2008 Dodge.
    Car manufacturers don't move that quickly in response to technology changes.
    12-07-2014 06:35 PM
  12. calvinrokks's Avatar
    I finally have information (but not a fix) as to why my Note 4 is having bluetooth connection problems on my 2014 Nissan Altima. The Nissan bluetooth department told me that it's a known Samsung issue that they're working on. Apparently, the Note 4 and Edge all use the newest AVCRP 1.5, which nobody else uses yet. Nissan told me that they were told by Samsung, that in their next update, they're going to revert the phones back to AVCRP 1.3, which is the standard in the industry. I don't know when that will happen, but at least I know why now. I have no idea what AVCRP is, by the way. I'm just relaying the info from bluetooth support.
    12-10-2014 02:28 PM
  13. LaTuFu's Avatar
    I'm going to call BS on that line of garbage you got fed. The Note 4 uses BT version 4.1 (which probably encompasses the AVCRP 1.5 codec). Your Altima most likely supports 4.0.
    I call shenanigans because I really don't see Samsung "rolling back" to a previous version. They didn't when this occurred when they went from BT 2.0 in the Galaxy S2 to 3.0 in the S3, and 4.0 in the S4. The other manufacturers simply update their firmware to be compatible with the latest BT version.
    Most likely, they've been given a line to repeat that makes it sound like the issue is on Samsung's side, so you won't sit there and gripe at them. Meanwhile, in 3-6 months they will quietly release a firmware update for your head unit that will be compatible with 4.1.
    That's how it has rolled out with other car manufacturers and previous versions of BT, I am pretty confident that's how it will continue.
    12-10-2014 02:37 PM
  14. ronb's Avatar
    ... I have no idea what AVCRP is, by the way. I'm just relaying the info from bluetooth support.
    If you are interested or quite tired and need to sleep.
    https://developer.bluetooth.org/Tech...ges/AVRCP.aspx
    12-11-2014 08:44 AM
  15. dh321's Avatar
    All,
    I'm very happy to report with the Sprint Update that rolled out yesterday, all of my data transfer with bluetooth issues are gone. When the song and title change, whether you're using a streaming app or play all works fine now and the screen updates after each song changes.
    lv2bsilly likes this.
    12-11-2014 01:27 PM
  16. ronb's Avatar
    All,
    Glad it is working for you. Good for Sprint for getting this one right as well.
    Ron
    12-12-2014 08:12 AM
  17. BizzyB's Avatar
    After the latest 4.4.4 update on my Note 3, I'm having many issues updating the track info over BT to my UConnect 8.4A with latest firmware (I updated it myself) on a brand new 2015 Jeep Cherokee Trailhawk. It doesn't want to work consistently, in several apps. The only one that seems to want to work all the time is Samsung's built-in music player, which I never use.
    What's odd is if I make a mixed playlist in Google Play Music, it [mostly] updates the track info fine. If I use the same artist and same album, my UConnect display never updates when changing tracks either automatically or manually via steering wheel buttons or touchscreen. If you go to a previous track, the display updates. Sometimes if I got to a different audio source, then back, it updates the track info.
    All and all it's extremely annoying with my brand new vehicle. I have full control of the music and audio plays fine, but track info doesn't update on the display consistently.
    12-12-2014 12:50 PM
  18. LaTuFu's Avatar
    Can you find out from Chrysler's websites what version of BT your Jeep's head unit supports?
    12-12-2014 04:05 PM
  19. lv2bsilly's Avatar
    All,
    That is great. Keeping my fingers crossed that the VZW update fixed this also!
    12-13-2014 03:04 PM
  20. lv2bsilly's Avatar
    The update from VZW fixed all my bluetooth meta data issues
    12-14-2014 12:32 PM
  21. alorlando's Avatar
    I had a Samsung Galaxy S III and never had a problem. I got the Note 4 and my bluetooth would switch to the phone sound intermittently. The Bluetooth would then show bluetooth setup and phone. I could not click on phone, but I could click on bluetooth setup. I would touch the bluetooth setup and it would go to the next screen. The only option visible was bluetooth off. Nothing would happen if I touched it. Everything else is grayed out. This was an intermittent problem. Sometimes it would work fine, others not at all.
    I brought the car in to Toyota and they took a look at the bluetooth and we were unable to get the bluetooth to come on. They said they reset the computer and the bluetooth was working. Again, it was working intermittently. Sometimes it works after shutting the car off and on. However, it shortly reverts back to the phone audio.
    I brought the car back to Toyota and they replaced the radio and a bluetooth part. The bluetooth worked fine for 3 days. I got into the car and the bluetooth would not come on. I got to where I was going and when I started the car again, the bluetooth was working, but quickly cut back to the phone audio. I got to where I was going and when I restarted the car the bluetooth was working.
    There is definitely something wrong with the car bluetooth and not my phone. The reason I believe this is due to if my phone did not work with the bluetooth, I should still be able to search for other bluetooth devices. The bluetooth in the car is off and does not allow me to add devices. So, even if I had another phone to connect, it would not find it. It is almost like I am in driving mode (even when parked) where I cannot do anything with the phone or bluetooth. The switching on its own to the phone has me completely baffled. Any advice would be helpful!
    Al
    12-17-2014 11:17 AM
  22. Tomster88's Avatar
    My Note 4 plays great but I get no album / song info on my car stereo, same goes for my wife's SUV. Worked great with my Note 3 on both vehicles. 2014 Durango ,2012 Mazdaspeed3.
    I've noticed if I use the Samsung music app via Bluetooth the song and artist info show up on my car screen. But if I use the Google music app to play music via Bluetooth it won't work. Maybe worth a try on your end. I have a 2013 Honda Civic.
    12-18-2014 02:25 AM
  23. Sir Droidsalott's Avatar
    Hey, That's how I used to start my 1976 Honda Civic.
    12-28-2014 04:16 PM
  24. shastrich2005's Avatar
    Hold the power button on you car stereo with the window switch up pump on your brakes 3 times then let go...
    Should reset
    What make vehicle is this for?
    12-28-2014 04:58 PM
  25. cvaria's Avatar
    I haven't worked my way through here but this was a bad answer. Blaming the car/stereo is bad. And this issue is, in fact, the note 4/edge... it's a known issue. Judging by the age of the original post, thd op knows this by now.
    01-05-2015 06:40 AM
143 ... 23456
  1. Google Nexus 6 vs Samsung Galaxy Note 4
    By blueyzfr6 in forum Phone Wars
    Last Post: 05-21-2015, 09:11 PM
  2. Samsung Galaxy Note 4 HELP! USB/SD Card Issues
    By BigCrimsonTX in forum Samsung Galaxy Note 4
    Last Post: 02-11-2015, 07:57 AM
  3. Replies: 2
    Last Post: 10-22-2014, 12:05 AM
  4. Replies: 1
    Last Post: 10-20-2014, 11:08 PM
  5. Replies: 3
    Last Post: 10-20-2014, 10:31 PM
