I have a 2012 Outback PZEV and my bofriends Iphone pairs fine.
Not my Note 4, Says it's paired - but wouldn't connect.
I had nothing until I downloaded the "auto connect" app.
Now it works sometimes - and sometimes I hear it ring - won't answer and sends caller directly to voice mail.
If it doesn' t get fixed soon - I've got til 15 Jan to return the phone. I will return it!
Try deleting it from the deck and re pairing it. That helped for me. The real help was to factory reset my Note 4. It still has BT issues but at least I can auto connect without powering the phone on every time I get in the car...I have a 2012 Outback PZEV and my bofriends Iphone pairs fine.
It's very possible. Even new generation models will sometimes incorporate older generation parts.I have a 2014 BMW X1 and my Note 2 worked perfectly with it. My Note 4 will make and receive calls, but it won't play any music. It shows in the display that it's set up for audio playback, so I'm puzzled. I can't imagine a 2014 car would already need a BT firmware update. I will try unpairing and repairing.
I finally have information (but not a fix) as to why my Note 4 is having bluetooth connection problems on my 2014 Nissan Altima. The Nissan bluetooth department told me that it's a known Samsung issue that they're working on. Apparently, the Note 4 and Edge all use the newest AVCRP 1.5, which nobody else uses yet. Nissan told me that they were told by Samsung, that in their next update, they're going to revert the phones back to AVCRP 1.3, which is the standard in the industry. I don't know when that will happen, but at least I know why now. I have no idea what AVCRP is, by the way. I'm just relaying the info from bluetooth support.
If you are interested or quite tired and need to sleep.... I have no idea what AVCRP is, by the way. I'm just relaying the info from bluetooth support.
Glad it is working for you. Good for Sprint for getting this one right as well.All,
I'm very happy to report with the Sprint Update that rolled out yesterday, all of my data transfer with bluetooth issues are gone. When the song and title change, whether you're using a streaming app or play all works fine now and the screen updates after each song changes.
All,
My Note 4 plays great but I get no album / song info on my car stereo, same goes for my wife's SUV. Worked great with my Note 3 on both vehicles. 2014 Durango ,2012 Mazdaspeed3. :-\
What make vehicle is this for?Hold the power button on you car stereo with the window switch up pump on your brakes 3 times then let go...
Should reset
The problem is not with your phone, it is with the firmware on your Outback's system. The iPhone uses an older BT codec that is compatible with the system. Your Note 4 does not. Contact your dealer and see if they have a firmware update available for the sound system. You may even need to research this on your own on a Subaru owner's forum, as the dealerships aren't always great about researching small details like that.
