1. KingTongue's Avatar
    I keep hearing different things when it comes to charging a phone. I just want to make sure I don't wear it out too fast.
    At what percent are you not suppose to let the charge drop below and such? Also is it true that one isn't suppose to keep phone plugged in at 100%? I always charge my phone when I'm sleep, but feel bad since I don't know if it's hurting the battery life.
    Posted via My Note 4
    10-20-2014 05:11 PM
  2. SpookDroid's Avatar
    Those are all myths of yore. Lithium Nickel-Cadmium batteries had the so called 'memory effect', where if you charged them before they hit 0%, they would 'remember' the state you started charging them in as the lower state. But new battery tech saves you the hassle. It doesn't matter if you charge it from 90% or 0% (it's not recommended to let it die out entirely too much, but it helps to do it once in a while to calibrate the reporting software in your device). Also, overload protection circuitry both in your phone and the battery itself, help prevent damaging effects of keeping your phone plugged in too long. After all, most of us plug our phones in at night, and most times, the phone charges fully before you wake up.
    10-20-2014 05:52 PM
  3. GregMargie's Avatar
    Those are all myths of yore. Lithium batteries had the so called 'memory effect', where if you charged them before they hit 0%, they would 'remember' the state you started charging them in as the lower state. But new battery tech saves you the hassle. It doesn't matter if you charge it from 90% or 0% (it's not recommended to let it die out entirely too much, but it helps to do it once in a while to calibrate the reporting software in your device). Also, overload protection circuitry both in your phone and the battery itself, help prevent damaging effects of keeping your phone plugged in too long. After all, most of us plug our phones in at night, and most times, the phone charges fully before you wake up.
    With all due Respect and just for my own knowledge....wasn't it the Ni-Cad batteries that burned a memory? Lithium are the current battery type used now that does Not?
    10-20-2014 06:23 PM
  4. SpookDroid's Avatar
    My mistake! That's what happens when you're thinking too many things at once haha. Yes, the old tech is NiCd, new thech is Lithium Ions.
    Here's a nifty little comparison.
    Li-ion vs NiCad - Difference and Comparison | Diffen
    GregMargie and jthouston like this.
    10-20-2014 06:27 PM
  5. GregMargie's Avatar
    LOL! I certainly wasn't trying to call you out on it, rather than clarify! I have many days like that! Have a good one!
    SpookDroid likes this.
    10-20-2014 06:33 PM
  6. Indie Fun's Avatar
    it's not recommended to let it die out entirely too much, but it helps to do it once in a while to calibrate the reporting software in your device.
    I never let my phone die out entirely because you never know when you will need it in full charge hahaha... thanks for the info anyway, i will let it die to "calibrate" it :P
    pantlesspenguin likes this.
    10-20-2014 06:56 PM
  7. SpookDroid's Avatar
    Yeah, it's good to do that at least once, especially when you just get your phone or after a factory reset. That way the software really knows what's 100% and nearly 0% and it can adjust the battery meter display, even more if your phone has an estimated time left for battery life.
    10-21-2014 11:30 AM
  8. pantlesspenguin's Avatar
    Once a crush called me and wanted to have a long chat when my battery was at 10%. I learned my lesson that night.
    10-21-2014 11:36 AM
  9. clatus's Avatar
    According to the battery experts, you will get the most out of your battery if you keep it above 50% as much as possible. Apparently full drains are bad for the battery because Li-ion's life span is measured in cycles and each complete charging cycle wears on the battery. Shallow charges prolong the lifespan.
    10-21-2014 11:53 AM
  10. SpookDroid's Avatar
    And with the purchase of the Note 4 comes a 50% discount coupon for all accessories under 50 bucks at the Samsung store. I just got an OTG cable, a spare battery with charger, a car mount, and a case for 70 bucks. Shweet! (And free shipping if your order is over 50 buckaroos, I think).
    10-21-2014 01:04 PM
  11. Almeuit's Avatar
    You can charge it whenever honestly .. I charge mine when it is convenient Also as Spook said I bought the spare battery / charger and now really don't have to worry .
    10-21-2014 01:46 PM
  12. fredwardnelson's Avatar
    This always confused me as well. There doesn't seem to be a clear straightforward answer on battery life. Even within this thread. So, I just charge it whenever I feel like it. I have a spare battery if something goes off but I don't worry about it anymore.
    10-21-2014 02:05 PM
  13. clevin's Avatar
    30-80
    @T-Mobile GN3
    10-21-2014 02:46 PM
  1. Google Nexus 6 vs Samsung Galaxy Note 4
    By blueyzfr6 in forum Phone Wars
    Last Post: 05-21-2015, 10:11 PM
  2. Replies: 2
    Last Post: 10-22-2014, 01:05 AM
  3. Replies: 3
    Last Post: 10-20-2014, 11:31 PM
  4. Why are all my sounds muting randomly?
    By janban34 in forum Samsung Galaxy S4
    Last Post: 10-20-2014, 08:38 PM
  5. Help: Background Data disabling itself? on Note 2 with KitKat
    By Buckot in forum Samsung Galaxy Note 2
    Last Post: 10-20-2014, 08:23 PM
