1. iOSConvert2k14's Avatar
    Hello! In a brief summary, I have had every version of the iPhone and tomorrow I am plunging into the Android world by getting a Note 4.
    1) Does fast charging damage the battery? Is it something you do only when needed or is it safe to do every charge?
    2) How does the battery work in low power mode? Is it what is hyped up to be? If I get below 20 percent on my iPhone 5S, I am running towards a charger.
    Thank you in advance!
    3) Anyone know how to turn off iMessage so I get all my texts? And what about my current contacts?
    4) How long does it take to get used to and familiar with Android?
    5) For my music, it is all on iTunes. Any cool free apps to sync my music to my Note 4?
    6) Random question but does the Note 4 come with any headphones like the iPhone? Not a huge deal because I use Beats headphones.
    Thank you so much!
    10-20-2014 05:46 PM
  2. Husker82's Avatar
    Go to settings, messages, and slide the iMessage slider.
    It can take a bit but it all depends on you really.
    This depends on your carrier
    Thank you so much!
    10-20-2014 05:50 PM
  3. tartrate's Avatar
    Thank you so much!
    See this thread: Switching from iPhone 5 to Note 4 this week. What should I do when I get my Note to ensure an optimal experience? : galaxynote4
    Most important: How to fix Apple's iMessage bug - CNET
    For your other questions:
    1. Don't worry about it. Also, guess what? Your battery is user replaceable!
    2. There is power saving mode. Then there is ULTRA power saving mode, which will give you a humongous boost on battery life. Your battery life will depend highly on individual use patterns and signal/reception.
    3. See above.
    4. Did not take me any time at all. You can learn as you go along and you will learn as much as you need to based on your needs.
    5. Spotify, Songza, and Google Music are all excellent.
    6. I think this is carrier dependent.
    10-20-2014 05:56 PM
  4. mhunter6378's Avatar
    Welcome to the forum
    1) No it doesn't hurt the battery. The charge rate will slow as the battery charge increases. You can turn it off in the settings if you want.
    2) There are two power saving modes. One just lowers system resources to save power. The other is more drastic and shuts off all but a few essential services. The latter can keep you running for a VERY long time.
    3) This one is a little trickier. On your iPhone, go into settings, messages and if your signed into iMessage with your Apple ID tap the area where it shows addresses where you can receive iMessages, then sign out, if you're not signed in with you'd Apple ID, then go into settings, messages and switch off iMessages. If you use an iPad and/or a Mac and use it for iMessages as well, you will need to sign out of all them too if they receive messages via your phone number.
    4) Not long, it's really quite easy. Spend some quality time here in the forums. Also watch some YouTube videos on the phone, they're very helpful.
    5) Lots of ways to handle that. Easiest at first is Samsung Smart Switch, just Google that and check out Samsung's website on it. You can also use Samsung Kies on your computer to sync, it will pull your library from iTunes.
    6) Not with Verizon or AT&T.
    10-20-2014 05:59 PM
  5. GregMargie's Avatar
    I have never been an Iphone user, but I found this....might help......How to transfer from iPhone to Android -- the ultimate guide
    This app from Samsung should be very helpful as well. I plan to use it to transfer from my Note 2 to Note 4, but it does help you transfer from Iphone to Android as well. Smart Switch: Data Transfer for PC, Mac & More | Samsung | Samsung
    10-20-2014 06:01 PM
  6. iOSConvert2k14's Avatar
    Thank you all for the warm and friendly responses! I am so excited to be making the switch. I consider myself a mid-level techie. I was much more into it in high school because college was filled with more pressing matters (girls typically). I am going to do as much research tonight as possible and walk into my ATT store tomorrow and hope they have some in stock. I live in Cincinnati so I can always shop around if need be.
    jerseygirl likes this.
    10-20-2014 07:05 PM
  7. tlo07's Avatar
    Make sure you turn off FaceTime too.
    Also as far as syncing your music goes I use iSyncr. It's not free but it's worth the money.
    10-20-2014 07:18 PM
  8. Closingracer's Avatar
    Google music is also a good choice and is free
    Sent from my SM-N910T using Tapatalk
    10-20-2014 07:21 PM
  9. MrDioji's Avatar
    I second isyncr. Definitely worth the money. I wirelessly sync every night at 3am. It also reverse syncs all my photos and videos to my hard drive.
    10-20-2014 08:15 PM
  10. GregMargie's Avatar
    You will be so impressed with all you can do with the Note and Android! The Spen is amazing! I am still using a Note 2 and by far the best phone I have ever had until I get the N4 that is!
    Android Central is filled with fabulous people that are always here to help and answer any questions! I learn new things here all the time! Good luck tomorrow!
    10-20-2014 10:19 PM
  11. iOSConvert2k14's Avatar
    I got the LAST white Note 4 in Cincinnati today! So happy! But am very confused as this is my first Android. Will be googling a lot this week haha. Quick question: any recommendations for app launcher? The stock one isn't my style.
    10-21-2014 08:40 PM
  12. TechNut79's Avatar
    I hear Nova Launcher mentioned a lot.
    Note 2 via Android Central App
    10-21-2014 08:51 PM
  13. GregMargie's Avatar
    Congrats on the phone and welcome to Android! I have always used the stock launcher, so can't recommend, but don't forget to dive into Google Play to find apps.
    iOSConvert2k14 likes this.
    10-21-2014 10:04 PM
  14. msokad's Avatar
    My friend was a Apple fanboy for the longest time. When they started integrated Hangouts, he made the switch. Now he loves android and told me at this time he has no plans to go back.
    As far as quesions, Search the posts and if you don't see what you are looking for, this a great forum to get answers.
    Welcome to the Android family
    10-21-2014 11:08 PM
  15. AlusionL's Avatar
    NOVA
    Nova
    Did I mention NOVA?
    And this coming from a guy who likes N4 Touchwiz
    10-21-2014 11:41 PM
  16. Chuondroid's Avatar
    Newbie question here also:
    1. Where can I DL good quality music (free preferably) for this android device?
    10-22-2014 12:25 AM
  1. How is Screen time on the Note 4?
    By thatdarnpunk in forum Samsung Galaxy Note 4
    Last Post: 04-01-2015, 02:45 PM
  2. Replies: 10
    Last Post: 10-21-2014, 01:03 PM
  3. Replies: 1
    Last Post: 10-20-2014, 07:01 PM
  4. Note 4 So am I the only one not realy into this phone??
    By bfuels1993 in forum Samsung Galaxy Note 4
    Last Post: 10-20-2014, 06:04 PM
  5. Replies: 0
    Last Post: 10-20-2014, 05:34 PM
