1. wilmasorphans's Avatar
    this is the first samsung i've had. i absolutely hate digital ring tones. is there any possible way to download actual songs by real "singers" onto this phone to be used as ring tones? would appreciate any help...
    10-21-2014 05:31 PM
  2. GregMargie's Avatar
    In addition, there are many music apps that you can use to make 'real' ring tones. You can also use apps such as Zedge, I use an app called Gtunes music.
  3. mhunter6378's Avatar
    If you have the songs on your phone the Samsung music player can make it a ringtone.
    10-21-2014 05:33 PM
  4. GregMargie's Avatar
    wilmasorphans likes this.
    10-21-2014 05:41 PM
  5. NIUHuskie's Avatar
    Just to pile on, I use one called RingDroid that I've always liked, but I'm assuming they're all pretty similar.
    10-21-2014 05:43 PM
  6. ktm_scott's Avatar
    I also use RingDroid. It's free and lets you slice any tune or sound into ringtone.
    10-22-2014 08:33 AM
  7. wilmasorphans's Avatar
    Thanks everyone
    I have checked out zedge but didn't find the songs I wanted will check out these others
    10-23-2014 06:41 AM
  8. wilmasorphans's Avatar
    I don't have any songs downloaded yet. Need to figure out how to do that
    10-23-2014 07:03 AM
  9. reesh11's Avatar
    You can also get ringtone maker to edit the song in case you only want a certain part as the ringtone.
    From my smokin' hot Note 4
    10-23-2014 10:14 AM
  10. Stephen Martino's Avatar
    Check out Audiko Ringtones app. It has tons of songs that you can use as a ringtone.
    10-23-2014 02:52 PM
  11. vitoa's Avatar
    I also use RingDroid. You can use it to cut portions of a song. Works great.
    With Android 4.4 you can just use entire songs from you gallery.
    10-23-2014 10:17 PM
  1. New Note 4 Setup
    By rinconmike in forum Samsung Galaxy Note 4
    Last Post: 10-24-2014, 08:21 AM
  2. Note 4 $30 off and all other TMobile phones and tablets until 10/28/14
    By Sammuel1973 in forum Samsung Galaxy Note 4
    Last Post: 10-23-2014, 08:31 PM
  3. Galaxy s3 deleted precious texts- can I retrieve?
    By greenginger in forum Ask a Question
    Last Post: 10-23-2014, 06:23 PM
  4. Verizon LTE on AT&T Note 3?
    By sungscow in forum Verizon Samsung Galaxy Note 3
    Last Post: 10-23-2014, 05:28 PM
