That's one reason why I got this phone, but I'll not have a chance to try it. Till the 22nd, but if it doesn't work, that'll stink.Has anyone tried private mode? When I try to turn mine on, it says failed.
Are you rooted? Or did you disable any system apps?
Sent from my SM-N910T using Tapatalk
So where is this private mode?
Yes and yes. The system apps I uninstalled/disabled weren't things that shouldve affected this though. I uninstalled the milk (music) app, and the Internet and touch wiz easy mode.
Does any other phone have such a feature?....
The S5 has it.
Well I meant from outside the Samsung Galaxy family lol
Oh, I thought you were literally asking if any other phone had it.
If your Knox counter is tripped, private mode won't work anymore.
Ohhhh. Didn't know that. Thanks. Lol. 1 point for Sammy. There are hundreds of apps that did that anyway. Screw Sammy.
But you don't need to root, to use the private mode, do you?
Be careful with those apps though. If you lose codes or uninstall while the files are hidden, usually all the files get deleted as well.
This Private Mode is built in, so not only can you not uninstall in, but you cant really lose any hidden data. And its also accessible via USB.
