1. bimoo's Avatar
    Hello there
    I got my Note 4 Yesterday and discovered that there is only Led Indicator Option to tick or Untick while in previous ones there was a menu that i could disable or enable the charging light and full battery light
    if i untick it it will disable all the Led Lights e.g. no light will flash if i recive email or whatsapp for example ..i tried to install some apps but nothing will fix it
    can any one tell me they have this problem or not ..i hate red light all the time while i am charging or green one if its fully charged it gets me confused now if its a notification for something i received or its just charging ..
    please any one could help with that i appreciate it a lot
    thanksAttachment 142288
    Attached Thumbnails Where is the Led Indicator Menu?-2014-10-20-21.14.06.jpg
    10-22-2014 02:21 AM
  2. beavo451's Avatar
    Steady red for charging, steady green for fully charged, blinking blue for notifications. What is so confusing about that?
    10-22-2014 08:35 AM
  3. DreamSTi's Avatar
    I know what the OP is talking about. I dont have my N4 yet, but my S5 the setting is located at:
    Settings > Display > LED Indicator
    From there you can adjust which ones you want on and when. Maybe they removed it from the N4?
    10-22-2014 09:03 AM
  4. bimoo's Avatar
    Do you think that I dont know how usually work this things !!!
    Read carefully and see the picture b4 u reply !
    10-22-2014 02:14 PM
  5. bimoo's Avatar
    I guess they remove it or maybe not in other roms
    10-22-2014 02:18 PM
  1. Replies: 9
    Last Post: 10-30-2014, 06:51 PM
  2. Sony Xperia Z3 Not Getting The Right Language
    By matt3166 in forum Sony Xperia Z3
    Last Post: 10-22-2014, 09:35 AM
  3. Is this the most hinky phone ever made?? s:
    By Si vis pacem para bellum in forum Ask a Question
    Last Post: 10-22-2014, 02:00 AM
  4. Note 4 The camera sensor is not being fully utilized!
    By cruiserandmax in forum Samsung Galaxy Note 4
    Last Post: 10-22-2014, 01:56 AM
  5. Why is my battery dying fast, I have an Samsung Galaxy S4?
    By Alexia Smith in forum Hardware Hideaway
    Last Post: 10-22-2014, 01:44 AM
