1. B0omSLanG's Avatar
    I got the new Note 4 S-View cover direct from Samsung using their promo. It wasn't until it was delivered until I caught wind of previous owners of the Note 3 S-View saying their oleophobic coating rubbing off / scratching on their actual screen. This would prompt me to immediately grab a tempered glass screen protector, though I bought this to avoid that, but the 2.5D screens don't properly apply at this point.
    I do feel like this S-View case was made differently. The protective screen doesn't seem to tough my phone's screen. It's also thicker and protects the back camera as well. Should I be worried?
    10-22-2014 07:29 AM
  2. Closingracer's Avatar
    I had one for the sy and works fine bnt Skipped it on the Note 3 because of the posts about it
    Sent from my SM-N910T using Tapatalk
    10-22-2014 07:46 AM
  3. B0omSLanG's Avatar
    Do you mean the S5 (sy)? It's not in your signature. Just wanting clarification.
    Thanks!
    10-22-2014 08:24 AM
  4. Closingracer's Avatar
    Thanks!
    I meant s4 lol. My buttons weren't working when I wrote that and was using my stylus and actually writing it in
    B0omSLanG likes this.
    10-22-2014 08:34 AM
  5. reesh11's Avatar
    My s view cover is just fine. I put a liquid screen protector on it I have no problems.
    From my smokin' hot Note 4
    10-22-2014 08:36 AM
  6. GoProDavidLe's Avatar
    I use the S-View on my Note 4 as well and have not had any issues. Used for for 3-4 days without a glass protector and now I use a glass protector.
    10-22-2014 08:38 AM
  7. Closingracer's Avatar
    I thought about doing that with the note 3 but came to the conclusion I hate screen protectors. Only ones I would try are glass.
    10-22-2014 08:42 AM
  8. reesh11's Avatar
    It's very good. It is actually water resistant and very slick. I like it. I usually get a screen protector and an Otterbox-esque case ASAP when getting a new phone but this is the least coverage and I like it.
    10-22-2014 08:51 AM
  9. B0omSLanG's Avatar
    I've never tried a liquid screen protector. Does it lose some of the intended tactile feel of the note 4 screen when using the s-pen?
    10-22-2014 10:37 AM
  10. reesh11's Avatar
    Nope its just kinda slick but fingerprints rub off with a breeze.
    10-22-2014 10:39 AM
  11. Ms. Treo's Avatar
    What liquid screen protector are you using? Thanks!
    10-22-2014 10:52 AM
  12. reesh11's Avatar
    Crystalusion
    10-22-2014 10:59 AM
  13. Beltelmel's Avatar
    Looks like it is good for reducing fingerprints and protecting against light liquid splashes. My concern would be that it offers no scratch protection only abrasion protection.
    10-22-2014 11:25 AM
  14. reesh11's Avatar
    True. Idk how good it is but I'd rather not have the halo problem. With the s view I don't have to worry much about scratches since it's always covered.
    10-22-2014 11:28 AM
  15. thegame161's Avatar
    No issues here with mine.
    10-22-2014 11:31 AM
  16. sqa4life's Avatar
    I also have the Samsung s-view. It looks really nice but it won't protect your note 4 from a good drop. I'll return it and use the crystal clear case.
    peaster3 likes this.
    10-22-2014 11:36 AM
  17. jlczl's Avatar
    I am thoroughly impressed by the S View case. When looking at cases I wasn't planning on getting it but I took it out of the package just to check it out. The quality is much better than previous generations. I love the fit and finish. It's also very easy to use folded back.
    drec70 likes this.
    10-22-2014 11:44 AM
  18. B0omSLanG's Avatar
    Everything seems to be an improvement except for one glaring exception: no quick s-note. Why, oh why, would they remove that from the window?!
    10-22-2014 12:09 PM
  1. Why does the S5 have a front camera worse than s3 and s4?
    By Sherryplus in forum Samsung Galaxy S5
    Last Post: 02-10-2015, 08:44 AM
  2. Why won't my PC and phone (SGS3) won't recognize each other?
    By Kalvis Grauds in forum Samsung Galaxy S3
    Last Post: 10-23-2014, 11:14 PM
  3. Help! Can't remove clock icon
    By kace2006 in forum LG G3
    Last Post: 10-23-2014, 11:19 AM
  4. anyone with udp pre order the n4 and keep udp?
    By steveinil in forum Samsung Galaxy Note 4
    Last Post: 10-22-2014, 02:36 PM
  5. Google maps, bluetooth and sound
    By albie999 in forum LG G3
    Last Post: 10-22-2014, 05:08 AM
