monsieurms
yes you right, only on when needed then turn it off per samsungs instructions. it will cause overheating in the phone. thats info right from samsung.
Hmm. That is an interesting curveball. Thanks for posting that. But I have to say, just went back to the manual they make available online and it says nothing of the sort. There is just an innocuous recommendation to use fast charging. Why would anyone recommend using something dangerous and not bother to set out any caveats?
You would think that if there were indeed a problem, they'd make that clear. But instead, the phone comes with an auto cue the first time you charge it: "Do you want to use the adaptive charger?" and says nothing else. That would certainly seem likely to make people use it all the time if there isn't going to be a warning to the contrary. After all, if they don't give you a downside, why would anyone want to turn fast charging off? Barring some warning on a downside, surely no one thinks slow charging is a good thing. Once a user turns this on, how many people are really going to keep turning it off and on 5 times a day or every time you go near a charger?? Not many, I'd guess.
It wouldn't be the first time we've heard something from a poorly trained CSR dealing with a brand new feature that they don't really know about. But I'd like to see ANY official documentation that suggests it is dangerous to the phone per se (as opposed to perhaps shortening battery life over a year or so..)
