raffygetsreal
This is not true because I already took mine off and it still has the problem. I have to double tap on the setting button to focus.
Okay you guys, I think I figured it out!
What I did was go on mode (open your camera up and tap on the left bottom circle}
Then I tapped on Manage Modes and only selected Virtual Tour and unselected all the other ones.
Hope that help..
Looking for input; should I just keep it for a while in the hopes that a fix comes out or should I send it back now? Thanks
it seems the camera won't focus properly. The close up shots are high quality but for the far shots its all blurry. Its not even that far lets say around 4-5 feet and the picture is blurry. I can get sharp focus on objects closer than 3 feet consistently, even in low light.
other than that the phone runs perfect, anyone know what might be causing this
tmobile version btw
Well I am having s problem taking pics,it says unfortunately gallery has stopped
Its not hardware guys
I restarted my note 4 in safe mode and the autofocus is lightning fast and doesn't stick
so its definitely software or an app causing the problem
Turn off your note 4
then hold volume down while pressing power. as soon as it screen comes on with vibrate let go of power and hold volume down until you see your home screen
you will see safe mode on bottom left
laugh your camera and see, it fixes it. so its software or an app
only app i recently installed is instagram hammy
