10-27-2014 09:53 AM
37 12
tools
  1. Almeuit's Avatar
    Thanks all. After playing with it some more, I was able to get it to work on the first try mostly.
    Still seems to be not as user friendly as Apple because you have 2 turn the screen on first, then swipe. With Apple, just press the button.
    Sent from my Verizon Samsung Galaxy Note 4
    Agreed .
    10-24-2014 03:15 PM
  2. Closingracer's Avatar
    I also registered 2 prints.. one being my index, one being my thumb. I use my thumb 100% of the time... and usually swipe it down at an angle (holding 1 handed). I expected to have more problems... but to my surprise, it has worked 100% of the time.
    That's what I do and works like 65%
    10-24-2014 03:43 PM
  3. LegalAmerican's Avatar
    I think it takes a bit of practice as sad as that sounds. It should be much more efficient, but I also am not extremely familiar with fingerprint scanning tech. I also have tried to scan my fingerprint on different angles, and it just gives me the same errors and will not seem to allow it. So for me, scanning the same print multiple ways hasn't been an option.
    Almeuit likes this.
    10-24-2014 03:50 PM
  4. Jose Bonet's Avatar
    I take it from this feedback that I won't be using this feature lol
    LegalAmerican likes this.
    10-24-2014 03:50 PM
  5. Almeuit's Avatar
    This -- For me as well.
    10-24-2014 04:02 PM
  6. Honey_184's Avatar
    I also used my thumb to register but when it asked me to train it, the first few times I did it with my thumb to the side... The way I would naturally do it when holding the phone... For the next few registration swipes, I did it with my thumb straight and of course in a downward motion. So far I haven't had to enter my backup password.... I've been starting my swipe by placing my thumb just above the down arrow on the screen and maintaining contact with the phone until my thumb literally clears the phone (I hope that makes sense?)
    10-24-2014 04:39 PM
  7. honey_bee_33's Avatar
    I guess I'm considered lucky because my finger print scanner works flawless. And it's my main source of unlocking my phone. I figured out the perfect way to swipe my finger that get me in 99.9% of the time.
    girls love tech too
    10-24-2014 07:57 PM
  8. ohioboy32's Avatar
    My gf swipes away on her gs5 and gets it in 99% of the time i then realized after watching her that i wasnt starting high enough on the screen now it like a charm but the op is right after getting annoyed with swipe failure i immediately thought how much better crapples touch id is..not complaining though NOTE 4 Decimates all
    10-24-2014 09:12 PM
  9. FBA's Avatar
    I have no issues - works every time!
    10-24-2014 09:48 PM
  10. lazerproof's Avatar
    You just have to get use to it. Start dragging your finger higher on the screen, and then onto the scanner. Drag as much of your finger as possible across the scanner. It may help, once you get familiar with it, to rescan your fingers. I find it to be very reliable. It works almost every time for me.
    10-24-2014 09:56 PM
  11. LegalAmerican's Avatar
    I think Apple clearly has the better TouchID capability here. Based on what i've seen and experienced. However, even with disabling my finger print scanner I still would take the Note 4 over an iPhone. If someone backed over my Note 4 with their vehicle, i'd still take the pieces of Note 4 over the iPhone. So a little finicky fingerprint scanner doesn't offend me.
    10-27-2014 09:46 AM
  12. Almeuit's Avatar
    Yeah their implementation of fingerprint lock is definitely easier and more convenient. Honestly from what I have seen with friends I would use Apple's since it seems to work 99.9% of the time... and I usually don't ever lock my phones.
    10-27-2014 09:53 AM
37 12
  1. Note 4 Camera/Focus Problem
    By DCuell12 in forum Samsung Galaxy Note 4
    Last Post: 03-31-2017, 10:46 AM
  2. [FREE][APP] Place2Go - places near you! Visit all the places!
    By Artem Bikusov in forum Android Apps
    Last Post: 11-25-2015, 03:39 AM
  3. Replies: 11
    Last Post: 11-02-2014, 05:06 PM
  4. Replies: 1
    Last Post: 10-24-2014, 03:40 PM
  5. Replies: 25
    Last Post: 10-24-2014, 03:29 PM
