Mobile data on wifi.
cbeattie411
Active member
Sep 21, 2012
39
I just looked at my My Verizon and noticed that my phone is still using mobile data even though I'm connected to wifi. Anyone else having this issue?
Almeuit
Moderator Team Leader
Moderator
Apr 17, 2012
32,277
23
It shouldn't be. The My Verizon app can be delayed in updating so you could be using mobile data .. get home .. get on wifi and use some data but then see that mobile data reflected an hour later.
cbeattie411
Active member
Sep 21, 2012
39
I have been home all day thinking I was using wifi so going crazy downloading filling up my new phone and then I looked at my mobile data and it says I've use 1.5 gigs today well since 10 this morning
VaDroid9
18
Mine is the exact opposite but I'm connected to my home wi-fi. My wife's is like yours and she's sitting beside me???
theoretically
176
Sometimes on my previous Samsung devices this happened, the 4g LTE icon stayed white even when on WiFi. Try rebooting and removing/reading the WiFi network
lsmachado
548
Mine looks just like yours, still using 4g LTE (the letters turn white) even though it should be using only WiFi, especially when updating apps. No download booster turned on. I'm glad you asked about this, because I've been wondering the same thing.
Posted via the Android Central App on my awesome Note 4
mty msi
769
3
When my AT&T N4 is on my home Wifi the 4G/LTE symbol is not present in the task bar and my mobile data is turned off. I don't know if that varies by carrier.
VaDroid9
18
So someone mentioned in another post about the app "Caller ID" that messes with the signal. I disabled it and now my 4G LTE is grayed out. Should be using WiFi now!
yellowcanary73
261
I'm on Verizon and I can turn everything off but my 4G is always lit up and you can see the arrows lighting up and down.
mak916
634
117
43
I've been having to is problem also. I mentioned it in another thread. I took the phone into Best Buy Samsung Experience and they re-download the software onto my phone. It didn't help. I am going to factory reset it tomorrow. If that doesn't work, I'll exchange it at Best Buy.
chuckawd
557
I think this is just how it works and it is not using Mobile data. I believe the arrows signify which source is actually being used for data transfers. On my N2 however, it would swap between the WiFi icon and 4gLTE icon depending on which source was being used.
chuckawd
557
So this is how mine is whilst on WiFi. I did not turn mobile data off.
chuckawd
557
Your 4g arrows aren't lit up and the 4gLTE icon is greyed out signifying that its using WiFi and not your mobile data.
nugj
325
Yea but "just how it works" does not explain the guy who has been home all day thinking he was on Wi-fi and blowing through 1.5 GB of data while he was at it. I think I will shut mobile data off completely while at home just to make sure.
Sleezzyy21
