1. Markurski's Avatar
    I'm still on a Verizon Samsung Galaxy Note 3 using pdanet+ wifi hotspot and am wondering if anyone has gotten pdanet+ to work on their note 4? I realize that the note 4 has the same OS, kitkat 4.4.2 and that it "should" work, but curious nonetheless!
    Thanks all!
    10-25-2014 12:01 PM
  2. mty msi's Avatar
    Thanks all!
    Search back a page or two and there's a thread on it. Verizon users are reporting the mobile hotspot works. It does not work on AT&T or Sprint, only the Bluetooth & physical tethering options work with those two carriers.
    10-25-2014 12:35 PM
  3. Markurski's Avatar
    Copy all, thanks for the info! I did a search but only found info specific to att.
    10-29-2014 12:46 PM
  4. Bullet2020's Avatar
    +1 Working for me too !!!
    10-30-2014 11:29 PM
  5. Lightshield's Avatar
    Quick tip, if you want to use the Foxfi tethering but prefer not to have a lockscreen passcode, you can use the app Dislock (formerly Pebble Locker) to override the lockscreen while also keeping the credentials for Foxfi to work. :-)
    10-31-2014 12:20 AM
  6. pparkey's Avatar
    Can you walk me through using Dislock to eliminate the pin lockscreen without clearing credentials? I read a review that got someone locked out of their phone.
    10-31-2014 01:12 AM
  1. Note 4 Auto Brightness, washed out and super bright?
    By billbrobaggins in forum Samsung Galaxy Note 4
    Last Post: 10-27-2014, 04:30 AM
  2. Do you play music/podcasts on your Note 4?
    By JGill2401 in forum Samsung Galaxy Note 4
    Last Post: 10-26-2014, 09:36 AM
  3. turning of data use when out of wifi
    By chocolateyum in forum Samsung Galaxy S4
    Last Post: 10-25-2014, 06:17 PM
  4. s3 not picking up wifi signal after inserting extended battery
    By Gautam Seshadri in forum Samsung Galaxy S3
    Last Post: 10-25-2014, 02:19 PM
  5. What accessories do you use that work/don't work?
    By TXGTOU in forum Samsung Galaxy Note 4
    Last Post: 10-25-2014, 12:59 PM
