03-14-2016 11:00 PM
94 ... 234
tools
  1. Jaron1226's Avatar
    Yes, I've experienced some scratching too. Although many people claim it's from "debris" I'm more than certain it's just the case itself which is causing the Note 4 to get these scratches.
    12-05-2014 07:11 AM
  2. Lady Grinning Soul's Avatar
    I've read accounts, possibly in here in this thread, of people finding some chipping around connectors when they first unbox it.
    If the cases are responsible, I imagine it might not be debris, to much as subtle abrasions as the skin-tight cases flex and rub, as can only be expected, through routine handling of the cased phone. In effect, diaper rash.
    12-05-2014 07:30 AM
  3. naira1's Avatar
    That white phone really looks bad with the scratches.
    Don't worry, in a few weeks time you'll be singing a different tune. I have thrown my Spigen away and going naked for now. I never had this scratches until I used the case but lucky enough mine is not as worse as the pics being shown here. At the moment am still trying to get the s cover case but undecided if I should buy the inductive one or the classic..
    I have a Spigen case and it is not scratching my phone!
    Sent from my SM-N910C using Tapatalk
    12-05-2014 09:22 AM
  4. Yogi217's Avatar
    I'm also going naked more. I'm thinking of getting the charging back too (non s view) because I've read that it helps protect the camera lense because it's a thicker back.
    I'm also using a leather pouch for times I need some protection (like putting in a bag or something).
    12-05-2014 09:36 AM
  5. Lady Grinning Soul's Avatar
    This gets to one of my main reservations about the N4. While it is not (as some might say) too large for a phone, it is nevertheless a large device to be carrying around, and the pockets and pouches that worked on smaller thingies may not be big enough or otherwise adequate for this tech slab. (But that's kind of OT for this thread.)
    12-05-2014 09:51 AM
  6. Yogi217's Avatar
    I have the bear motion one. It's big, but it's slim. If I have it in the pouch inside of a jean pocket, it's no more cumbersome than when I have the Slim armor case on.
    I'm probably going to get a different one that has a slot for credit cards so it can double as a wallet. I don't like the folio cases, so this is a good option for me.
    12-05-2014 10:27 AM
  7. Lady Grinning Soul's Avatar
    Do you happen to have a convenient link to the cases you're describing?
    The idea of a good one that doubles as a wallet.... or a wallet that contained a compartment for the N4... could be a good thing.
    At the end of the day, the phone IS your wallet.
    12-05-2014 10:36 AM
  8. fragologist's Avatar
    I've been getting scratches too from the spigen tough armor case. My wife has the hybrid case from spigen and hers has no scratches. I find it hard to believe that debris is the cause. When I take my phone out I don't see any debris especially anything that would cause scratches.
    I am in the process of making my Note 4 self aware.
    12-05-2014 11:32 AM
  9. Yogi217's Avatar
    http://www.amazon.com/Bear-Motion-No...cUvbUpU4106250
    http://www.amazon.com/gp/aw/d/B00NBG...cUvbUpU4106250
    First one is the one I'm using. It's tight when you first get it, but the more you use it, the better it fits. I push the phone in all the way, and it's super tight. To get it out, I push from the end so that it sticks out a little and then pull it the rest of the way. The negative reviews are complaints about the tight fit, but I like that because I know the phone won't slip out.
    Another user here recommended the wallet type one that is posted second. I may get that next.
    12-05-2014 11:40 AM
  10. doohsun's Avatar
    i picked up this case one of the best Samsung Galaxy Note 4 Case from Urban Armor Gear - Clear Case – URBAN ARMOR GEAR
    no problem with scratches at all.
    12-05-2014 11:57 AM
  11. Tim VeePee's Avatar
    I have the Spigen case and yes it has scratched mine. The problem is, even though the plastic is soft, its still to hard. When you slide the case off it scuffs the edges because its so tight. The thing is if I want to remove my SDcard or just switch cases, I can't do it often because eit gets a new scratch. I usually use the flip case. I bought this case specifically because I wanted to protect the metal sides which I know will damage if dropped.
    I don't have as many scratches a the guy in the photo, but I have some.
    Is there a way to buff them out is what I'd want to know.
    The problem with Samsung latest phones, is it not as easy to replace that middle piece as it was on the Note 2. On the Note 2, you removed all the screws and use a tool to scoop the display out of the middle section. The Note 3 didn't allow this. You had to remove everything and place it on the new piece like you're building the phone. That sucks. The Note 4 I need to look at the video, but I am sure its similar.
    12-05-2014 03:56 PM
  12. nugj's Avatar
    Seems to me it is a tough deal all around. But as far as the Spigen cases go...I had two of them here in the early days of case hunting. One I sent back and one I modified. So it is still here. But i won't use it. My experience was that they were tight on entry and removal but that the fit was a bit off once you had the N4 in the case. So to me that looked like the worst of both situations......probably risking some scratches putting the N4 in the case or removing it and then a few more just because the N4 was moving around a bit in the case while it was in there. I have been thoroughly unimpressed with Spigen's case effort with regard to the N4.
    Paul Caliz likes this.
    12-05-2014 04:51 PM
  13. Paul Caliz's Avatar
    I also use a spigen protective case. It ruined my aluminum metal finished note 4 Bezel. And it pissed me off. But we cant blame spigen or other brands. Because we are not forced to buy and use it. But definitely it is caused by this spigen product.
    02-08-2015 10:50 AM
  14. Paul Caliz's Avatar
    02-08-2015 10:56 AM
  15. PhilNUK's Avatar
    Not got a case and no scratches at all on my phone and I have had the phone since launch week
    02-08-2015 10:58 AM
  16. adobepro's Avatar
    My Defender for the Note 4 scratched my edges. I have the defender for the S4, and the fit was perfect in the plastic shell. For the Note 4, I had to apply some force to fit it into the bottom shell and then apply force on the top shell to click into the notches. It was one of those I should've known better but this should just work frustration moments where I knew it was going to scratch the frame and I should've stopped there but continued. In hindsight, I should have applied some tape to the edges, but Otterbox should have used the same soft material they have on the inner plastic shell around the shell to prevent this. This is just bad, a new $700 phone scratched by a device that is supposed to protect it. Maybe a little vein, but c'mon, I'm using this monster protector to protect it from scratches, dings and falls, and already it's scratched up. Not happy, and won't use Otterbox anymore. I'll post some pics tonight once I open it up to get my SIM card number
    03-26-2015 10:25 AM
  17. kns_soon's Avatar
    Verus Thor case! It doesn't leave any scratches on the bezel too. I use it for 3 month and have dropped couple of times. Today i took off to check, its still fine. But reminder if you want to buy the verus thor case, please take out the plastic case first before pulling off the rubber one off your phone.
    04-11-2015 08:56 AM
  18. Mecomug's Avatar
    I am using the tech 21 cover. No scratches. It's a great looking cover and has the added protection. It doesn't make the phone feel bulky either. I highly recommend it
    04-11-2015 09:50 AM
  19. appleused3455's Avatar
    used otterbox for 1 week for my iphone 6s plus, when i opened it for cleaning tada! scratches on the sides
    03-14-2016 11:00 PM
94 ... 234
  1. Why is my battery app not working ?
    By chickenrooms in forum Ask a Question
    Last Post: 10-28-2014, 01:16 AM
  2. Why is my Note 3 using 400+ mb/month?
    By Kyle Mason1 in forum Android Apps
    Last Post: 10-27-2014, 07:43 PM
  3. Galaxy s4 went through the wash - can it be saved?
    By 1o951o8 in forum General Help and How To
    Last Post: 10-25-2014, 11:07 PM
  4. note 3 screen issue
    By Daniel Stojanov1 in forum Ask a Question
    Last Post: 10-25-2014, 06:29 PM
  5. Replies: 0
    Last Post: 10-25-2014, 05:31 PM
