Camera Hints - To Avoid Zooming with volume key....
Switch your horizontal position so that the camera button is on the left! ("Samsung" on the right)
That will keep your left thumb off the volume key - which is something I repeatedly do because I need to get a good grip on the phone to shoot steadily. Your on screen icons will also reverse.
Note 4 image gallery: http://www.pbase.com/isabel95/samsung_galaxy_note4
Re: Camera Hints - To Avoid Zooming with volume key....
Good tip - Thanks for sharing!
You're welcome - payback for all the help I've received here. Great forum!
Great tip!
But mine doesn't zoom. It takes the photo. I must've changed that setting somehow.
Originally Posted by
PaulaO Great tip!
In the camera settings you can set the volume buttons to either take a picture, zoom or record video.
I found that. And more. Thanks. There's a lot in there. I didn't know you could do all that with the video. Gonna have fun with the dogs tomorrow.
I don't use volume keys for zoom anyways, I set them to shutter. Taking pics with the volume key ever since Note2.
I keep mine for zoom.. with 4K you can zoom in a little any not worry about quality.
