01-27-2016 08:18 PM
29 12
tools
  1. Amandeep Singh13's Avatar
    Has anyone else seen this?
    When writing on the lower right side of my Note 4 screen with my S-Pen (the side the pen is stored in) the cursor will be slightly off from where the pen is actually touching. As a result, anything I draw or write will look derptastic once it traverses to that portion of the screen.
    Is this common? Is it just a calibration issue? Is there a fix?
    Thanks in advance!
    06-15-2015 01:38 PM
  2. Amandeep Singh13's Avatar
    Magnet case is the problem. S pen doesn't work properly when i use magnet case.
    06-15-2015 01:40 PM
  3. Khaled Omar1's Avatar
    hi .. i have faced this problem but i discovered it cause of the mobile cover just use the mobile without the cover and it will works well.... try it.
    07-12-2015 12:49 PM
  4. lacmac's Avatar
    I had the same problem. Couldnt use 1cm on the right hand side.
    Use this code to test the S pen hover.
    *#0*#
    When you open the S pen hover test,you have a series of blocks from the top left to bottom right, hover from top to bottom till they all turn green.
    It didn't work the first time. So I rebooted and tried again, this time it worked.
    01-27-2016 08:18 PM
29 12
  1. I want to buy your Note 10.1 (2012) s pen tips
    By mangurian in forum Samsung Galaxy Note 10.1
    Last Post: 01-19-2015, 04:46 AM
  2. Samsung Galaxy Note 4 hate cases but scared to go naked
    By Lambertoid in forum Samsung Galaxy Note 4
    Last Post: 01-09-2015, 10:45 AM
  3. Organizer app for Note 8 to use S Pen.
    By pinkyxo in forum Samsung Galaxy Note 8.0 Tablet
    Last Post: 01-06-2015, 08:36 AM
  4. Will updating to KitKat 4.4 let me customize the home screen?
    By Metal Militia in forum Ask a Question
    Last Post: 01-06-2015, 12:04 AM
  5. Samsung galaxy note 4 and Imessage issue
    By rycon325 in forum Samsung Galaxy S4
    Last Post: 01-02-2015, 06:54 PM
