Galaxy Note 10 Deal: BOGO at Verizon!
01-27-2016 08:18 PM
29 12
tools
  1. ProtoformX's Avatar
    Has anyone else seen this?
    When writing on the lower right side of my Note 4 screen with my S-Pen (the side the pen is stored in) the cursor will be slightly off from where the pen is actually touching. As a result, anything I draw or write will look derptastic once it traverses to that portion of the screen.
    Is this common? Is it just a calibration issue? Is there a fix?
    Thanks in advance!
    10-25-2014 08:56 PM
  2. PaulaO's Avatar
    I just tested mine using Sketchbook and didn't notice anything being off. Gah, I hope you've not gotten a bad one.
    10-25-2014 09:15 PM
  3. ProtoformX's Avatar
    Me too! That would be incredibly irksome.
    10-25-2014 09:28 PM
  4. TaterMay's Avatar
    I have the same issue. I think all corners have the issue for me. Is there any way to calibrate it?
    10-25-2014 09:31 PM
  5. jpr's Avatar
    Do you have a case on or other accessory with a magnet in it?
    10-25-2014 09:49 PM
  6. honey_bee_33's Avatar
    The note 3 was having the same issue while using a case with a magnet. I read in the note 3 forum last year around this time.
    girls love tech too
    10-25-2014 09:53 PM
  7. ProtoformX's Avatar
    I currently have no case on it. I bought the S-View flip cover and put it on VERY briefly. I did not like it, and took it off.
    My phone is currently caseless until I can find one I like.
    The weird thing is I'm positive that it's only THAT corner. Everywhere else the pen is very accurate on the screen.
    10-25-2014 09:58 PM
  8. jpr's Avatar
    girls love tech too
    It's not actually an issue with the Note 3 or 4. It's an issue with the case and the magnet in it. A lot of people who had fake S-View cases had the problem because of the magnet either being badly placed or too strong. The S-Pen works through a magnetic field.
    honey_bee_33 likes this.
    10-25-2014 10:02 PM
  9. jpr's Avatar
    Ok, this is slightly tedious to do, but open S-note and scribble repeatedly all around the edges of the screen. Do this without lifting the pen the whole time.
    10-25-2014 10:04 PM
  10. ProtoformX's Avatar
    That was interesting. When I do it that way, it's as if the pen anchors the cursor back to it, and it appears to be most consistent. It's when I lift the pen and try to put it down again that the cursor is off to the left or up slightly.
    10-25-2014 10:10 PM
  11. jpr's Avatar
    This code will not work on all carriers (some disable it) but if you want to test your screen, you can go to this hidden menu. in the phone dialer dial *#0*#
    If that works you will get a menu with several options. You can choose Wacom test and there are also hovering tests and touch tests, etc.
    firefly_flames likes this.
    10-25-2014 10:20 PM
  12. ProtoformX's Avatar
    Didn't work. Guess Verizon disables it (also, WTH!? I disable the touch bubble sounds because I found them to be annoying as heck.... I kept dial sounds enabled, only to discover that they too are the silly bubbly noises!? Why can't we have normal key tones!?).
    Guess I'll just have to deal with a derpy corner of the screen. Thanks anyway.
    10-25-2014 10:31 PM
  13. jpr's Avatar
    Verizon always disables it.
    Well, the S-Note thing I had you do is as close as anyone has come to finding a way to calibrate an s-pen. If you feel like it, you can keep trying it over and over and see if it improves.
    I don't know if you want to put up with something on a brand new phone, unless it's very minor and you're fine adjusting the way you write or tap or whatever. You might want to see if Verizon will replace it unless that would be more trouble than it is worth to you.
    10-25-2014 10:36 PM
  14. ProtoformX's Avatar
    I think it's minor enough that I could learn to adjust. Just annoying that a brand new phone had an issue like this. Wonder if replacing the s-pen tip would fix it....? Probably not.
    10-25-2014 10:39 PM
  15. jpr's Avatar
    You might as well try replacing the tip. I assume you got several replacements with your phone. They last a long time so using up one of them won't be an issue for you.
    10-25-2014 10:41 PM
  16. itsnotmeitsyou's Avatar
    You just had to point this out, didn't you?! Lol. I checked mine and it does the same thing. To show an example, I drew 3 sides of a square without lifting the pen, then lifted the pen and drew the last line. The pen was lined up, but the line didn't go in the right spot. Samsung Galaxy Note 4 S-Pen issues with lower right side of screen?-uploadfromtaptalk1414305773761.jpg
    10-26-2014 01:42 AM
  17. reesh11's Avatar
    This works my AT&T version. Although I was scared for a second as I couldn't get out of the screen. Also it is very blinding regardless of your current display settings so beware.
    From my smokin' hot Note 4
    10-26-2014 02:05 AM
  18. Brendon Jeffers's Avatar
    I have this issue using the handwriting feature
    Sent from my SAMSUNG-SM-N910A
    10-26-2014 02:38 PM
  19. swampystorm's Avatar
    I also just noticed this. I was wondering why I had to press harder on the back space of my keyboard on right hand lower screen than the rest of it. Then noticed the circle thingy under the pen isn't under then pen!
    I am using an s view case
    10-27-2014 02:23 PM
  20. ProtoformX's Avatar
    Just to give you an idea of what I'm looking at...
    I tried to put dots on lines in groups. Granted, my accuracy isn't phenomenal... but you can see what happens to my grouping towards the lower right corner.
    Attached Thumbnails Samsung Galaxy Note 4 S-Pen issues with lower right side of screen?-screenshot_2014-10-27-21-17-48.jpg
    10-27-2014 08:29 PM
  21. firefly_flames's Avatar
    Thanks JPR for that !!! Weird thing is - everything works fine! Really heartbroken.. Bought my phone outright for $800 and then this!
    This is what I am going through... and that "void" has gotten bigger
    ~> sharetheview.wordpress.com/2014/11/13/when-companies-dont-give-a-crap/
    11-16-2014 06:18 AM
  22. jack_kay's Avatar
    my s-pen works even in that angle
    11-16-2014 07:53 AM
  23. Juan Chavez5's Avatar
    I think there may be a magnet on the bottom right corner that detects if the spen is in place. Not sure just coming up with stuff. I have that same problem. Is there a way we can check, if a magent is placethere?
    Katrina White1 likes this.
    12-30-2014 03:47 AM
  24. kobe008's Avatar
    Mine does it too, on the lower right of the screen the little dot that hovers where the pen is shows up a little higher than where the pen tip actually is. Works fine on the other 3 corners. I'm guessing there is something that is detecting the s-pen being inside the phone that is doing it. Not an issue and I don't see how this really hurts anything.
    Juan Chavez5 likes this.
    12-30-2014 10:01 AM
  25. Yasser alfaraydi's Avatar
    hi,,
    I have the same issue.. but I found it is only in the fake s cases that has magnets !
    04-22-2015 09:13 AM
29 12
  1. I want to buy your Note 10.1 (2012) s pen tips
    By mangurian in forum Samsung Galaxy Note 10.1
    Last Post: 01-19-2015, 04:46 AM
  2. Samsung Galaxy Note 4 hate cases but scared to go naked
    By Lambertoid in forum Samsung Galaxy Note 4
    Last Post: 01-09-2015, 10:45 AM
  3. Organizer app for Note 8 to use S Pen.
    By pinkyxo in forum Samsung Galaxy Note 8.0 Tablet
    Last Post: 01-06-2015, 08:36 AM
  4. Will updating to KitKat 4.4 let me customize the home screen?
    By Metal Militia in forum Ask a Question
    Last Post: 01-06-2015, 12:04 AM
  5. Samsung galaxy note 4 and Imessage issue
    By rycon325 in forum Samsung Galaxy S4
    Last Post: 01-02-2015, 06:54 PM
