11-04-2016 01:47 AM
272 ... 45678 ...
tools
  1. tlo07's Avatar
    I tried to use GPS to get to the UPS Store the other day and Google Maps tried to get me to turn into an empty field. I was not impressed. I guess when I desperately need to use GPS I'll have to dust off the ol' iphone 6. 😕
    Sent from my iPad using Tapatalk HD
    01-25-2015 01:53 PM
  2. cross157's Avatar
    Hello everyone, I want to add my name to the fray of users experiencing intermittent GPS problems on the Note 4. I've tried all the apps and workarounds suggested in this thread and the only thing that's shown any promise is removing my SD card, using the phone without an SD card isn't a viable permanent solution but it's reduced the GPS disconnects from every 20-40mins to once or twice in 12 hours.
    Carrier: T-mobile
    Model: SM-N910T
    SD-Card Class 4
    Mode: GPS only and High accuracy
    I'm going to report this to Samsung.
    Update:
    I performed a factory reset and left the SD card removed. So far it's been 2 days without losing the GPS.
    Samsung responded with about a dozen suggestions, all of which are basic and essentially useless
    01-27-2015 11:13 PM
  3. helloimme's Avatar
    dpham00:
    * Thanks for your comments and suggestions.
    * Your suggestion to contact the Verizon executive prompted me to make the attempt. I tried to contact the Verizon executive in both Northern CA and Southern CA areas, from their profile pages. At the bottom of each profile page is a "Contact" link that opens a new pop-up window with a contact form. However, after filling in all the fields, when I clicked "Send" absolutely nothing changes with the screen. It still shows the exact same contact form and fields, with my entries, as though I didn't click "Send," even though I did click it. I tried this for the Northern CA president several times, then for the Southern CA president, on two different browsers, and got the same result every time. It was rather frustrating. I finally printed it out and got a mailing address from the general Verizon Wireless web site "Contact Us" page.
    UPDATE:
    I spoke with the Northern CA Verizon executive today. When I tried to send a summary of the situation via the web contact form, it wouldn't send, as noted in a previous post. There was no indication of a maximum number of characters that can be typed in the message field, and it never limited my typing as I typed my message (the way some message fields would stop allowing any further typing once the maximum length has been reached). So I tried to send a very brief note instead, simply stating that I had an issue to discuss that I couldn't resolve at the Verizon Wireless stores, and the contact form was not sending my message so in case it was due to message length, please let me know how else to contact him. In response to this, he called me.
    He stated that the first Verizon Wireless store should not have refused to exchange my device, because they have a 14-day exchange policy that is supposed to be "no questions asked" and so it didn't matter what my reason for the exchange was. He stated he can change my upgrade dates so that I'm back to my upgrade eligible period as though I never purchased a new device back on Jan 8 of this year, and I can go back to Verizon Wireless to purchase the phone again. I asked what if I get another defective device, and he said then they should exchange it. I asked what if the one that gets exchanged is also defective, and he said then they should exchange it again until I get one that works. However, when I clarified this with him later, he changed his tune about this and went back to saying I would get one exchange opportunity.
    I am considering, then, to purchase the device again, and if the GPS function doesn't work, then return the product and that's that. However, they may try to hit me with a restocking fee, which would not be appropriate if the return is due to a defective product.
    Perhaps interestingly, he didn't ask which store or which manager would not allow the exchange in the first place. I did mention I had the store addresses, and names of all the reps and managers I spoke to.
    01-29-2015 02:01 AM
  4. gosdis's Avatar
    I have a brand new Note 4 that the GPS doesn't work and I found the solution that worked for me on accident. I was trying some of the suggestions on this thread when I tried the one about taking out the Sim card. I took off my bumper case, removed the back, battery, and sim. I put it all back except the case, booted the phone and the GPS started to work. I was thrilled but that is not the end of the story. Later I put my metal bumper case back on the phone and my GPS stopped working. I removed the case an it worked. This whole time it was the metal case acting like a Faraday Cage around my GPS receiver in the phone. I bought a plastic case and threw away the metal case and haven't had a problem since.
    skatergirl likes this.
    02-08-2015 11:47 AM
  5. lsmachado's Avatar
    Sounds reasonable to me. I remember back in the day before smartphones, buying phone cases from vendors in mall kiosks and flea markets or ebay.
    When they were installed on the phone, the signal strength would diminish drastically. These cases were made in other countries that probably still used lead-based paints or other metals in their manufacturing process. At any rate, the phones would function normally when the case was removed.
    Posted via the Android Central App on my bodaciously awesome Note 4!
    02-08-2015 01:52 PM
  6. MsBlingberry's Avatar
    I have the same problem with my GPS too! Help
    02-08-2015 02:53 PM
  7. Dominick079's Avatar
    I posted my problems on Reddit and got some interesting advice. I was told to take out my sim and try it. It didn't work, so I put my sim back in. On a whim, I used GPS to get to the gym. It worked better than it EVER has! I had a little hiccup when it briefly thought I was on a different highway, but it corrected itself and was very accurate throughout the trip. I was overjoyed! I used it to get home....and it was back to normal . I got another piece of advice to try downloading the map and using it offline. I'm going to try that tonight. It's strange that the sim might be causing the issue, because one of the things I tried was exchanging the sim. Maybe it's an issue of the sim card contacts?
    Yeah I swapped my SIM on my AT&T Note 3 because I was having some issues with the GPS and it fixed the problem for me. I don't know if it will fix it for everyone but its worth a try
    Posted Via AT&T Note 3
    02-08-2015 03:05 PM
  8. Dominick079's Avatar
    Are people having issues with the Note 4 GPS on every carrier or just on AT&T? Im picking up my Note 4 in March and hope I don't have this issue. If I do then I will continue to exchange it until I get one without the this issue. Because I know not every single Note 4 has this problem. My friends Note 4 GPS works flawlessly on AT&T
    02-08-2015 03:12 PM
  9. rsawitzky's Avatar
    Mine is on Sprint and i'll run into this problem sometimes. I uninstalled maps back to factory and it seemed to help, but still sometimes loses connection. If I plug in into my car charger though, strangely, it'll work perfectly and i haven't had a problem since.
    02-08-2015 05:10 PM
  10. sparksd's Avatar
    I haven't seen it so far on my Sprint Note 4.
    02-08-2015 06:54 PM
  11. funbob's Avatar
    My note 4 edge has had gps performance drops from day 1. Gps signal lost is a regular report on my phone! I am very disappointed with this device. I would not recommend getting one.
    02-09-2015 02:10 AM
  12. funbob's Avatar
    My note 4 edge from att drops the gps lock every time I use it.
    02-09-2015 02:23 AM
  13. pantlesspenguin's Avatar
    I still urge everyone that's having difficulties to call Samsung about them! Let them know everything that you've tried to get it working so they can isolate the issue and work on an update.
    cross157 likes this.
    02-10-2015 01:22 PM
  14. Dominick079's Avatar
    So if the Note 4's GPS problem is mainly on AT&T branded Notes then its an AT&T issue not a Samsung issue. If it is a problem with all Note 4's then its a Samsung issue. This is why I don't buy new devices when they first come out. I usually wait a few months before purchasing a new device.
    02-10-2015 02:00 PM
  15. proctorc's Avatar
    When I first activated was having issues with signal and GPS. Switched Sim card with my old Samsung device and restored everything. From what I have read it seems most of issues were resolved by switching Sim cards.
    02-10-2015 03:11 PM
  16. dhelfinstine's Avatar
    Tmo Note 4- started having issues about a week ago. Fixed it by pressing on the screen. Seriously. Press hard on the bottom or top of the screen. It will make a lite cracking sound (don't do it too hard). With GPS status went from no fix in 10 minutes inside to 10/20 satellites in seconds. Seems that there is something loose. Problem with my SGS4 too. My Nexus 5 sitting right next to it had no issues. Never tried new sim, but would if it helped. Pressing seems life a stupid fix, but for me it has worked for several days.
    02-10-2015 10:04 PM
  17. pantlesspenguin's Avatar
    That was one of the first things I tried and it didn't help.
    02-11-2015 02:21 PM
  18. Terry Winge's Avatar
    Hello,
    Okay so too was having problems with gps on my N4 using Google Maps. I downloaded GPS essentials and also started My Tracks and Maps on a recent trip. Both Essentials and Tracks showed all the gps data my phone was receiving however when I tired to use maps it was not working. It would jump to my current location but no update my track or show me driving through a field. I downloaded Navigation and tested it today. It worked perfectly showing where I was at and also updating correctly as I went on a short trip. I have not uninstalled Maps and tried a re-install yet but I doubt that that will work. While I prefer Google Maps what I have will work right now. I have also gone into my settings and turned off high accuracy and selected gps only.
    I hope this helps someone else. I honestly read through a fair portions of the posts but didn't read them all. Please feel free to contact me if there is anything I might have missed and there are questions.
    Blessings to you all,
    Terry
    02-27-2015 04:10 PM
  19. rage151's Avatar
    Don't know if this will work for the Note, but it worked perfectly for mine and my wife S3's. We got our phones at the same time and both of them had the same GPS issues that everyone describes in this thread. I rooted mine, downloaded GPS toolbox, etc... Nothing worked. I finally found a thread somewhere that said to snap off the back cover and very gently tighten any phillips (4-way) screws that are visible. I was skeptical, but neither one of us could trust our GPS on a trip, so I gave it a shot. I tried it on mine first and it worked. Did it on my wife's, it worked again. That was about 2.5 years ago and they still work fine. It was like night and day.
    I don't know how or why it worked...didn't make much sense to me. But it did.
    If any screws are visible after you take off the back cover and battery out, try tightening them just a little bit (DO NOT OVER-TIGHTEN!).
    02-28-2015 12:08 AM
  20. lrknight's Avatar
    I have a Samsung Note 4 on Sprint and it has had this same issue from day one.
    The phone gets GPS location fine when sitting still. As soon as the car moves, the signal is lost. It updates again at the next light or stop sign. It's very frustrating. I don't get turn-by-turn directions but it does SHOUT "You've arrived at your destination" when I get to the destination (without help from the phone!).
    02-28-2015 09:39 AM
  21. Dominick079's Avatar
    I was having GPS issues with my Note 3 until I swapped the SIM. Now that I have a Note 4 I haven't had any GPS issues at all and I use it quite often.
    Posted Via The AT&T Note 4
    03-08-2015 12:57 AM
  22. anon9358096's Avatar
    I have a quick question. When you are not moving does your gps work fine? I recently have been having a problem where it doesn't lock on at all for a time if I am stationary or moving. For example sitting on my desk right now next to the window I have no fix with 1-2. If I torque the frame a little bit them I seem to get more satellites.
    03-08-2015 09:28 PM
  23. Porkchopexpress1969's Avatar
    explain swapping out the sim. I was planning on moving from a Iphone 5 to a Note 4. And I would like to use this feature, and I'm in ATT. If I pick up this phone not sure on how to swap a sim. With my old Iphone's sim?
    03-08-2015 11:47 PM
  24. Dominick079's Avatar
    Well your iPhone 5 uses a nano sim and the Note 4 uses a micro sim. So when you purchase the Note 4 they will automatically give you a micro sim. The GPS issues seem to only effect the AT&T version of the Note. I have many friends on other carriers with a Note 3 and 4 and they never had a single issue with their GPS. As I stated before it may not fix the GPS but I gave it a shot anyway and once I changed the SIM in my Note 3 the GPS worked perfectly. But now I have a Note 4 and haven't experienced any issue with the GPS
    03-17-2015 05:33 PM
  25. robor007's Avatar
    So still no reliable fix for this issue? I have had several Samsung devices (S2 Skyrocket, Note 1, 2, 3 and now 4. My Note 3 had occasional GPS issues. My Note 4 is next to effing useless. And it is an AT&T device that had issues on AT&T and is now unlocked on TMobile. Same issue on both carriers.
    It's been over 6 months and Samsung hasn't addressed this issue. I'll be selling this thing and getting another device. Cya Samsung.
    03-20-2015 11:08 AM
272 ... 45678 ...
  1. Replies: 1
    Last Post: 11-02-2014, 11:57 AM
  2. I just got the note 4 it's so slow how can I fix this?
    Last Post: 11-02-2014, 09:44 AM
  3. My Galaxy s3 is taking forever to charge, why?
    Last Post: 11-02-2014, 09:37 AM
  4. Samsung Galaxy Note 4 How do I adjust Notification Screen timeout?
    By monkeypimp in forum Samsung Galaxy Note 4
    Last Post: 11-02-2014, 09:34 AM
  5. Replies: 1
    Last Post: 11-02-2014, 09:28 AM
