1. pantlesspenguin's Avatar
    I can't find this under lock screen options.
    10-27-2014 10:35 AM
  2. B. Diddy's Avatar
    This usually can't be modified on an unrooted device.
    10-27-2014 10:37 AM
  3. pantlesspenguin's Avatar
    Really? That's frustrating. I can't even glance at my notifications without unlocking the device first!
    10-27-2014 10:43 AM
  4. B. Diddy's Avatar
    How long is it staying on? Maybe you could try a 3rd party lockscreen app--perhaps those have screen duration options.
    10-27-2014 11:04 AM
  5. bembol's Avatar
    IIRC WidgetLocker offers this.
    10-27-2014 11:13 AM
  6. delco714's Avatar
    Display screen timeout.. even if you power button the screen off it won't lock for whatever time you set it. Just make sure the hit the power button to lock function is off which is in lock screen settings. Change that to 30 seconds in the lock automatically setting
    10-27-2014 11:29 AM
  7. B. Diddy's Avatar
    I believe that only affects the time the screen stays on once you're past the lockscreen. It doesn't affect the screen timeout when you're on the lockscreen.
    10-27-2014 12:06 PM
  8. pantlesspenguin's Avatar
    This is correct. I'm so used to pulling my notification shade down from my lock screen, but even when I do that it goes off after a couple of seconds. I guess I'll just need to get used to unlocking first.
    10-27-2014 12:27 PM
  1. How long does it take for your phone to charge 1-100
    By 15vailo50 in forum Samsung Galaxy Note 4
    Last Post: 02-12-2018, 01:10 PM
  2. Replies: 16
    Last Post: 10-29-2014, 09:56 AM
  3. Anyone know if a N6 vs Turbo compare chart is someplace?
    By Fable in forum Motorola Droid Turbo
    Last Post: 10-27-2014, 05:48 PM
  4. How to switch the "back" icon with the "recent apps" icon?
    By Derek Stapleton in forum Samsung Galaxy Note 4
    Last Post: 10-27-2014, 10:40 AM
  5. How to get screen to dim while on call?
    By chuckawd in forum Samsung Galaxy Note 4
    Last Post: 10-27-2014, 10:24 AM
