1. ansa82's Avatar
    I just can't get better focus. Seems like it should be able to get better closeup focus? Can anyone help?
    10-28-2014 10:44 AM
  2. Almeuit's Avatar
    It should work on just tapping where you want the camera to focus on. Try doing that to see if it will help with the focus.
    10-28-2014 11:42 AM
  3. Almeuit's Avatar
    Such as here I tapped on my puppy's face / neck area and it focused.. Then I snapped.
    10-28-2014 11:43 AM
  4. ansa82's Avatar
    Yep I see a circle that I tap. Doesn't seem to be focusing with that
    10-28-2014 12:44 PM
  5. bertsirkin's Avatar
    I've had issues with focus as well. I can usually get it to focus, but sometimes it's a bit finicky.
    But, you may want to make sure that the plastic protective cover on the camera lens has been removed - it's not real obvious that it's there, but if you haven't removed it, it may be affecting your focus.
    10-28-2014 12:53 PM
  6. ansa82's Avatar
    Yep I removed it a couple of days ago. It was only covering the outer part anyways. I don't think it would interfere with focus even if it was left on
    10-28-2014 01:58 PM
  7. PraetorianGuard14's Avatar
    I've been wondering if my camera had the plastic..it's the Verizon version. I can't seem to feel it and when I tried "picking" it, it felt like I was hitting the camera surface itself so I don't really mess with it to avoid scratching it.
    10-28-2014 02:00 PM
  8. ChemMan's Avatar
    You have to look very closely, maybe get a flashlight and illuminate it from the side. It is very difficult to see in some cases.
    10-28-2014 02:03 PM
  9. lostsoul2's Avatar
    you can try selective focus or try to DL the food photo app from samsung if not see if the google camera app might have something for you.
    10-28-2014 02:03 PM
  10. PraetorianGuard14's Avatar
    Any tips on how to remove it? Would a piece of tape work?
    10-28-2014 02:04 PM
  11. mhunter6378's Avatar
    yes, tape works perfectly
    10-28-2014 02:08 PM
  1. Internal vs. Phone storage help needed
    By Maryann Krokowski Graham in forum HTC One S
    Last Post: 11-19-2015, 04:15 PM
  2. Replies: 6
    Last Post: 11-06-2014, 02:55 AM
  3. How do I get the most of the Moto Gs camera?
    By Ding Dong2 in forum Moto G (2013)
    Last Post: 10-31-2014, 09:51 AM
  4. Camera not working, static through speakers and overheating.
    By reflectivenight in forum HTC One Mini
    Last Post: 10-28-2014, 12:30 PM
  5. This is helping my battery life?
    By WP_290 in forum Ask a Question
    Last Post: 10-28-2014, 12:29 PM
