1. Phantasmal Images's Avatar
    I have an iBolt xprodock for my Note 4. It charges the phone, but won't switch it into dock mode. So I switched to Nova Launcher, so I can have my home screen in landscape, and turned on developer options so I can have the screen stay on while it's charging. Not really concerned about losing the sound output through the miniUSB since my car has bluetooth. What I'd like to do is use an NFC tag to turn on and off the keep screen on while charging option, instead of having to do it manually every time I put the phone in and take it out. Anyone know if this can be done? I don't actually have any NFC tags to try it myself, nor have I ever tried to use them before.
    The xprodock is great, fits the phone and holds it very securely. I did have to flip the charging arm to the other side so the volume rockers wouldn't be on the bottom support, but that wasn't hard to do. I have it mounted on my dash, although I wish it was just a little lower. I'll probably pick up a different 17mm ball mount for it soon that can be adjusted down a bit.
    10-29-2014 07:04 PM
  2. SpookDroid's Avatar
    You might be able to do that without NFC tags, with Tasker. It sounds like something it should be able to do quite easily by detecting the charging state.
    10-29-2014 07:12 PM
  3. Phantasmal Images's Avatar
    But then it would also keep the screen on when charging at home wouldn't it? That was what I was trying to avoid.
    10-29-2014 07:14 PM
  4. SpookDroid's Avatar
    Not if you configure it properly. Maybe detect your car's bluetooth or your home's WiFi and add that as a condition for the recipe.
    10-29-2014 07:19 PM
  5. Phantasmal Images's Avatar
    Didn't know you could get that involved... I'll have to look into Tasker.
    10-29-2014 07:21 PM
  6. SpookDroid's Avatar
    Quite a few Tasker guides lately in Android Central. You might wanna check those out
    10-29-2014 07:24 PM
  7. Lefty Drummer's Avatar
    Did you end up getting the *new* charging arm for the N4 you mentioned in another thread?
    10-29-2014 08:58 PM
  8. Phantasmal Images's Avatar
    Not yet, and I'm thinking there's no need to now that I figured out how to work around it.
    10-29-2014 10:50 PM
  9. Lefty Drummer's Avatar
    How exactly did you work around it? Just curious to know, since at some point I'll get the N4 and as I mentioned in the other thread really love the iBolt dock. I read your full post, but I thought you had said originally that the current arm wouldn't charge your N4.
    10-31-2014 09:34 AM
  10. Phantasmal Images's Avatar
    I replaced the combination usb/aux cable with a regular usb cable. That allowed for charging, but wouldn't activate dock mode. So it was just a matter of working around that issue (as explained above). I haven't gotten around to seeing if Tasker can be setup to turn on/off the screen on while charging setting yet, so I've been doing it manually.
    Lefty Drummer likes this.
    10-31-2014 02:58 PM
  1. Galaxy S5 Case Help (Suggestions Requested)
    By Layuth in forum Samsung Galaxy S5 Accessories
    Last Post: 11-04-2014, 07:35 AM
  2. Replies: 1
    Last Post: 11-02-2014, 11:57 AM
  3. My Galaxy s3 is taking forever to charge, why?
    Last Post: 11-02-2014, 09:37 AM
  4. Samsung Galaxy Note 4 How do I adjust Notification Screen timeout?
    By monkeypimp in forum Samsung Galaxy Note 4
    Last Post: 11-02-2014, 09:34 AM
  5. Replies: 1
    Last Post: 11-02-2014, 09:28 AM
