1. Tokerovin's Avatar
    Pretty straightforward question.
    Does FoxFi Wireless tethering mode work on the Verizon Galaxy Note 4?
    I am hoping to purchase a Note 4 soon and a major concern is whether or not the FoxFi tethering app supports WiFi Mode on Verizon's Note 4.
    FoxFi with wireless tethering has been confirmed to work on non-rooted S4. S5, and Note 3. I would assume that it will at-some-point work on the Note 4 but if anyone could confirm this I would be eternally grateful.
    Thanks,
    10-30-2014 10:54 AM
  2. theoretically's Avatar
    Yes FoxFi does work on the Verizon note 4. I use it now
    DreamSTi likes this.
    10-30-2014 10:57 AM
  3. Tokerovin's Avatar
    Thanks for the quick response guys. I can't wait to join the current generation!
    10-30-2014 01:47 PM
  4. pparkey's Avatar
    Foxfi works on Vzw Note 4 but requires a lock screen pin. I have to clear credentials each time done using to go back to no lock screen. Small hassle to have tether on ULD plan.
    10-30-2014 02:07 PM
  5. CarlGHarris's Avatar
    Hi pparkey. Can you explain what you mean in more detail? I'm new to the Note 4 and foxfi (and have never before used a hot spot), so I don't follow what you're writing. Thanks in advance!
    11-10-2014 05:44 PM
  1. How water resistant is the Droid Turbo?
    By kjjb0204 in forum Motorola Droid Turbo
    Last Post: 02-13-2020, 07:01 PM
  2. Replies: 12
    Last Post: 11-10-2014, 12:33 PM
  3. Replies: 2
    Last Post: 10-31-2014, 07:50 AM
  4. To Do list for Note 4?
    By damink23 in forum Samsung Galaxy Note 4
    Last Post: 10-30-2014, 01:02 PM
  5. Galaxy S5 or Galaxy S5 Active?
    By Tara Rayburn in forum Samsung Galaxy S5
    Last Post: 10-30-2014, 11:11 AM
