1. AppleHatr's Avatar
    New to android phones (I have a Verizon Note 4), I've tried using several pairs of headphones with the mic & volume buttons but I've found that the volume buttons are not working, even though the main button does work (to start/stop the music). I also tried on my wife's Note 3 and my volume buttons wouldn't work there either. Is there a setting I'm missing or is this a Galaxy or Android issue?
    10-30-2014 04:48 PM
  2. SpookDroid's Avatar
    Well, I've used my Note 3's headset with the Note 4 since I got it and the volume rocker on the headset works just fine. The control button too.
    SOME headphones are not compatible with all phones (you can thank manufacturers for changing their signals, like Apple does) so you might be using a headset that's not compatible with yours. But at least in mine (T-Mobile), I've used the Note 3's and they work.
    10-30-2014 05:09 PM
  1. Is there a car navigation dock for the new Droid Turbo?
    Last Post: 10-31-2014, 06:58 AM
  2. Replies: 2
    Last Post: 10-30-2014, 11:45 PM
  3. Replies: 10
    Last Post: 10-30-2014, 08:02 PM
  4. How do I put my Galaxy S5 Active into Download Mode?
    Last Post: 10-30-2014, 04:03 PM
